Front radius arms bushing swap, how to jack ? - Defender Source
Old September 29th, 2011, 04:28 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
For those who have been there already, if I remove both front radius arms so in can press out then press in new bushings, should I support vehicle on chassis or on front axle ?
My bet is on chassis but there is probably something I'm not taking in consideration.
- Charles Eames
Old September 29th, 2011, 04:37 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
definitely by the chassis
Old September 29th, 2011, 05:12 PM
Chassis for sure.
Old September 30th, 2011, 01:42 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Chassis, no question.
If the axle moves a bit is is not a problem. If you have problems getting it lined up use some ratcheting tie downs to move it back into place.
Old September 30th, 2011, 07:25 AM
The Dro
Dro
1988 Ninety
The chassis, once you remove the RA there is no support.
Old September 30th, 2011, 08:41 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
A pair of jack stands on the chassis horns right behind the bumper.
I prefer removing just one radius arm at a time, but if you have take them some place to have the bushings R&R'd then you can do both at the same time.
Never-Seeze on the new bushing sleeves and bolts. Refitting is a lot easier if you cut about a 1/4 of the length off an old bolt and taper it to use as a guide pin. Insert it from the nut side, then insert the new bolt as normal to knock out the guide pin. A pipe wrench is handy for twisting it if the radius arm is cocked slightly
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
chassis or both; Caution! While working on my diff, having first to remove/loosen my SG 3-link, I was surprised or maybe lucky to see my entire axel pivot forward. I was not under the car, however, it could have easily dropped...I'd still be under there; flowers on the bonnet. I had supported both the chassis and the axel, but being careless, had more support under the axel; the spring tension was enough to pivot/move the d-90 forward on the chassis jacks...it did make for more working room, but it could have ended very badly...not sure how many times I had previously used the same practices without incident.
Old September 30th, 2011, 09:15 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Chassis, obviously, but I also put the removed tires under the truck so if it falls it can't go too far.
Semper Fi!
Old September 30th, 2011, 10:21 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I was thinking about leaving the tires on, eventually, and prop the chassis just high enough to take the pressure off the wheels.
- Charles Eames
Old September 30th, 2011, 11:49 AM
Antichrist's Avatar
Antichrist
Tom Rowe
It's a lot easier if you remove the wheels. If you do one side at a time the axle won't rotate more than fractionally.
I also place jack stands under the axle and use my floor jack under the radius arm to lower it and lift it back in to place.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
The second thing you have to do is support the axle using jackstands. The axle weighs a metric ****load even without tires and can easily overwhelm you. Maybe if you are on steroids or Jean Valjean it's not an issue, but once you disconnect the driveshaft and even one radius arm the entire axle assembly is just dead weight.
Tires should be off the axle before you do the work. Unless you have very small tires, you won't be able to get far enough under the truck to work on it - without having to jack the truck up into the sky. Also it makes the axle weight worse than it already is.
For reassembly - if you can bolt the radius arms to the axle before you connect it back to the frame, do it. We did it the other way and aligning the axle to fit to the radius arm is difficult.
Old October 4th, 2011, 10:57 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Old bushings out, new bushings in, we did made a cup/tool
to push the new bushing in without risk.
Made a mistake ordering new nuts, it's m16 FINE THREAD,
so when you order, be sure it's a 1.5 pitch (not a 2.0).
Tomorrow I am putting this thing together.
Is there a left and a right side for the radius arms ?
Next is panhard
- Charles Eames
ac
Used D90 Radius Arms Northface Wanted 3 March 29th, 2005 08:42 PM
Front GBR Extreme Duty 23/24 inner axles, D110 CV's and spindles w/ brass bushing lwg For Sale - Parts 8 February 9th, 2005 01:08 AM
Looking for HD driveshafts, radius arms, and more chrisvonc Wanted 9 October 4th, 2004 05:05 PM
Radius and Trailing arms chrisvonc Defender Technical Discussions 18 June 9th, 2004 10:21 PM
