Front propshaft U-joint ... - Defender Source
Old July 9th, 2006, 11:36 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Does any one know if there is a North American part number (Dana Spicer or other) that will replace the U-joint on the front propshaft of my 1984 D110 or do I have to order the OEM one.
Just asking !
Thanks all !
Pat
Old July 10th, 2006, 12:28 AM
How funny, Mike H just replaced a front U-Joint on a 1984 D110 with a Spicer around January. He had it done at his favorite local shaft place "John's Shafts and Stuff" in NH. At the very least, you could pull it, send it to John, and he could identify it.
Old July 10th, 2006, 11:14 AM
Ahh but Jim I only had the rear shaft done. I would be willing to bet that the front shaft on a 90 is the same as a 110. Either Precision 344 or 369, or Spicer 5-153 or 5-4. Those are the numbers for the front and rear shafts of a D-90. If you can pop out a U-joint and bring it to the parts place and compare it to those numbers.
Old July 10th, 2006, 06:23 PM
Retrofit's Avatar
Retrofit
Pat
Roger ...Wilco !
I will use those numbers to find one cause every time I go to the parts places, they look at me funny when I tell them what it is for.
Thanks Mike.
Pat
Old July 10th, 2006, 07:01 PM
Yeah I think we all run into the same problem, most of the time the parts store people see me coming and just let me walk out back and grab what i want. But Last time i was in Autozone and I asked for a U-joint for a 94 Land Rover Defender there computer listed the right part! So if you have an autozone near you I would give it a try and just tell them you have a 94 Defender.
Old July 14th, 2006, 02:41 PM
Retrofit's Avatar
Retrofit
Pat
Yep !
It was bang on ! Got all 4 U-joints today and the numbers were right even for a 1984 110.
Thanks again.
Have a nice weekend all !
Pat
Old June 28th, 2008, 08:45 PM
Just FYI, the u-joints on Janey ('84 110, front and rear the same size) are not the same size as on a '94 D90 (Neapco 1-0005). They have the same cap diameter, but are longer from end to end.
Anyone know the cross reference number for 110 u-joints? Did you record the numbers you used Pat?
thanks
charles
Old June 29th, 2008, 10:50 AM
Retrofit's Avatar
Retrofit
Pat
Hi Charles,
I took my U-joints to napa with these numbers and found replacement with these. I can't remember witch is witch.
U-Joints
Hope it helps.
Pat
Kirk Lazarus, Tropic Thunder
Old June 29th, 2008, 07:10 PM
Thanks Pat
I had Advance look up a couple of these and I think the 369 cross referenced to a Neapco 1-0153 which they stock and fits my truck. I have only done the front so far but the rear appears to be the same size.
Thanks again,
charles
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
