Front Propshaft Seal - Defender Source
Old August 11th, 2013, 11:41 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Is there a seal or cap on the front end of the propshaft to prevent the grease from slinging out? I was replacing my u-joints today and noticed that this cap is missing from the shaft, so any grease I shoot in there is just slinging out. And just to be clear, I'm talking about the shaft, not the u-joints.
Old August 12th, 2013, 09:43 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Mine has a rubber boot on the larger shaft that "swipes" the smaller shaft as the two slide together. No metal though.
Old August 12th, 2013, 09:47 AM
loykd's Avatar
loykd
Ken Loy
Dennis, is that on the shaft itself, or on the end?
Old August 12th, 2013, 11:28 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
It's on the big shaft & it has a locater ring (part of the rubber swipe) to keep it in place on the lager/outer shaft. The outer shaft has the zirk fitting on it & the internal spines for the short shaft that has the U joint yoke. Yes it's on the end but it covers the juction's were the to splined shafts join. I'd say it's (the rubber boot) about an 1-1/2" long
Old August 12th, 2013, 11:31 AM
loykd's Avatar
loykd
Ken Loy
Right. I've got that rubber boot/sleeve, too. What appears to be missing is something covering the very end of the prop shaft, like a cap that holds in the grease.
Old August 12th, 2013, 11:36 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Mine have that hole too, I always thought it was a relief port for excess grease. Mine was 2 years old 6500 miles on it when purchased, I doubt the PO removed anything.
1987 LHD 90 2.5td broadstone For Sale - Vehicles 4 May 21st, 2013 07:27 PM
RR Classic Driver's Front seat bottom access door jack frisch For Sale - Parts 0 February 27th, 2005 01:50 AM
D90/110 Front Door Seals jabber Wanted 3 February 21st, 2005 12:16 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
