Front prop shaft options - Defender Source
Old June 27th, 2015, 07:22 PM
seanreaganphoto
Sean Reagan
1995 Defender 90
Hello - I have a NAS D90 in Mexico & am looking at options for replacing the front prop shaft. This piece from LR is retailing at $1,000 plus in the US.
What are my options? Are there other LR prop shafts or other manufacturers I can consider? Any chance the 2.2 liter diesel Defender down here uses the same prop shaft? Thank you. Sean
Old June 27th, 2015, 07:27 PM
a discovery 1 shaft is a solid shaft as opposed to hollow on a defender and a direct bolt in for your 90
Old June 27th, 2015, 07:30 PM
seanreaganphoto
Sean Reagan
1995 Defender 90
Thank you - the Disco I prop shaft is also very expensive in the US. Is the Disco I the same in other parts of the world - can I get the Disco I prop shaft from the UK and expect it to fit as well?
Thanks again,
Sean
Old June 27th, 2015, 07:36 PM
Buy one used! They are pretty cheap from a wrecking yard.
Old June 27th, 2015, 07:38 PM
seanreaganphoto
Sean Reagan
1995 Defender 90
Thanks, not a bad idea - although not too many Disco Is or Defenders down here.
Old June 27th, 2015, 07:43 PM
X2..
Old June 27th, 2015, 07:49 PM
What about having one made in Mexico? I would think there are plenty of driveline shops that make prop shafts all day.
Old June 27th, 2015, 08:07 PM
seanreaganphoto
Sean Reagan
1995 Defender 90
Yes, I am looking into local manufacturers. Any ideas on US shops that have done this work for NAS Defenders?
Old June 27th, 2015, 08:46 PM
Here you go:
http://www.defendersource.com/forum/...tml#post650839
Old June 27th, 2015, 09:11 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
GBRUtah.com
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 29th, 2015, 01:08 AM
sean, are you aware that the existing driveshaft can be refurbished almost infinitely using replacement u joints?
Old June 29th, 2015, 02:13 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Tom Woods Driveshafts in Utah is a good option for a new shaft.
Unless your shaft is damaged beyond repair, there's no reason why you have to replace it. A good driveline shop can rebuild it locally for cheap and rebalance it no problemo. Your shaft should use 1310 U-joints, which are among the most common in the world and certainly available in Mexico.
Latin America practically invented recycling. I'm sure there's someone local who can square you away. A rebuild might cost $100-200 in the States but that's mostly labor. In Mexico, you should be able to get it done for far less.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old June 29th, 2015, 07:22 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by roverman2010 View Post
GBRUtah.com
x2!!
Old June 29th, 2015, 07:31 AM
Used disco one propshaft is $50-75 here. New U joints cost around $12-$20 ea depending on what you buy from whom.
Old June 29th, 2015, 07:46 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
NAS D90's came with 1300 series u-joints.
2.938" cap to cap and 1.063" cap dia
Neapco 1-0005
Precision 344
GKN TVC100010 (I think)
Spicer 5-4x (NLA)
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 29th, 2015, 10:11 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
If anyone is looking at getting some Tom Woods product let me know via PM, I might be able to help you out.
H/D double cardon D90 front prop(drive) shaft Landy_Andy For Sale - Parts 5 June 18th, 2013 10:38 AM
Land Rover Prop Shaft Tools SafariHP The Vendors Loft 19 July 12th, 2011 06:48 AM
DII Front Prop Shaft Recently Rebuilt Paul Grant For Sale - Parts 0 December 11th, 2008 10:16 PM
Land Rover Prop Shaft Tool SafariHP For Sale - Parts 70 January 30th, 2008 08:21 AM
Series Rear prop shaft, new. KevinNY For Sale - Parts 1 July 15th, 2006 04:28 PM
