front pinion angle ?? - Defender Source
Old February 12th, 2005, 03:25 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Can someone here with an angle finder let me know what the stock pinion angle is on there truck? I would like to know what the angle is when you put the angle finder against the flat spot on the bottom of the 3rd member? IF someone does not understand where I mean, I can take a pic. I would like to get this from a fairly stock truck with not much lift if possible but I will take anything right now...
I want to get a base line of what stock is before I start screwing with mine with the 3-link. I forgot to take an initial measurement before taking it apart .
Legend in My Own Mind.
Old February 12th, 2005, 04:38 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I don't get the problem. If you have a front CV shaft, just point it right at the angle of the shaft minus 1.5 degrees or so. Am I missing something??
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 13th, 2005, 08:11 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I know but I am still interested in the stock angle. Then you know that your caster is perfect. I want to set mine to stock and then work from there. As you go up you raise yoru caster angle so less is better as long as you have no vibration. Can anyone help?
Old February 13th, 2005, 05:21 PM
redrover
Guest
Posts: n/a
Randy if you have a double cardon you need to point diff up as dave spec. I have mine set up like that. But i did experiment with the stock driveshaft once. With the stock style drive line you want the angle of the yokes on the transfer case and diff to be in parallel. You can easily do this with the 3link. The problem in my case was that the drive shaft sat against the HD cross member when I had the camber adjusted correctly. So On my truck it didnot work. JP
Old April 11th, 2005, 02:01 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Just for your guys knowledge when I had my front end aligned today, the guy checked my castor and said it was perfect at 4.5 positive on each wheel. It steers great with no vibs from the driveline either.
Old April 11th, 2005, 08:08 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Randy I will be setting mine up soon & I am going to try to run a stock ds. Just waiting for tierod ends.
Old April 11th, 2005, 08:21 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
How much lift do you have?
Old April 11th, 2005, 08:31 PM
byrdseye
Bruce Byrd
99 D1
What angle did you end up with...........as measured with an angle finder on the bottom of the rockguard? I just finished my install yesterday and haven't found the magic "no vibe with enough castor setting yet!
Bruce
Old April 11th, 2005, 08:44 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Randy, it is posta be 2.5.
Defender Front Diff Pinion Shearpin Defender Technical Discussions 2 July 10th, 2009 03:23 PM
Pinion Angle Corrector / Radius Arms nldrvr The Vendors Loft 2 November 20th, 2008 09:45 AM
rear pinion angle correction KevinNY Defender Technical Discussions 11 April 6th, 2007 03:35 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
