Front output flange - Defender Source
Old September 10th, 2009, 02:38 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Front output flange
Is there a trick to removing the nut that holds the front output flange on the T/C? Am I just not trying hard enough.
Thanks......Again
Old September 10th, 2009, 02:40 PM
It is meant to be tight, try harder. Impact gun is the easiest....
Old September 10th, 2009, 02:41 PM
Put two nuts on the studs, insert prybar to lock it down (I do NOT advise locking the diff and putting on the e-brake as a way to hold it) and hit her with a big breaker bar of impact gun.
So yes, you are just not trying hard enough.
Old September 10th, 2009, 02:43 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
You guys are fast.
I like the idea of not using the E-brake and diff lock...... That is what I was doing and didn't want to really yard on it.
Old September 10th, 2009, 02:44 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I think the shop manual says to use a specialized rover tool which bolts on to a few of the bolts and keeps it from spinning...
I just use an impact gun....
Check out this pic... its someone's makeshift tool for the diff flange.. something could be similar for the TC;
http://discoweb.org/rotoconversion/6torque.JPG
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old September 10th, 2009, 02:48 PM
The engine puts out 200 lb-ft * 3.6 * 3.2 = 2300 lb-ft.....
You are not going to break the t. case. Diff lock on, low range, 1st gear, hand brake on..... Breaker bar.
Old September 10th, 2009, 03:55 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
All done. You should have seen me standing on the breaker bar with my hands on door frame..... Quite the balancing act.
Thanks again guys
Front TC output shreik! owen Defender Technical Discussions 3 January 2nd, 2010 11:39 PM
DII Front output flange weissbrewer Wanted 5 August 20th, 2007 12:40 PM
DiscoveryII Front Output flange Davis Wanted 0 August 5th, 2007 01:20 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
