Front Output Bearing - Defender Source
Old October 15th, 2007, 08:27 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I am going to replace my front output bearing in my LT230. I have read the manual and am looking for any practical experience doing the job "in situ." I have done the same job on a Borg Warner and done a rear on the LT230 so I have some experience with this type job but the linkages and the diff lock are the bits that worry me.
Thanks for your comments.
Old October 15th, 2007, 09:47 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Are you doing the input or output? For the output all you have to do is remove the front drive shaft from the transfer case and remove the flange. Then just use a seal puller to pop it out, and drive in the new one. Simple, and you don't have to remove any linkages!
Old October 15th, 2007, 11:15 AM
landrovered
S. Smith
The seal is easy this is the bearing.
The bearing will come out easy enough but the housing must be removed in order to drive the race out of the housing. That's where the fun comes in.
Old October 15th, 2007, 12:12 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Could you use a slide hammer with a hook end?
--Benjamin Franklin
Old October 15th, 2007, 12:35 PM
epninety's Avatar
epninety
Dave Haynes
Ibex 240 2.8TGV
I just did this job 2 weeks ago, you don't need to pull the housing. Behind the drive flange is an oil seal. Behind that, is a big circlip. Once you remove that, you can pull the shaft, complete with bearing (it's a single roller race).
Why are you changing it? Is it noisy? They quite often have a lot of up/down/side play, and it doesn't seem to cause any particular problems.
I had a worrying amount of fore/aft float which I didn't understand, which is why I pulled mine apart.
Dave
Old October 15th, 2007, 01:56 PM
landrovered
S. Smith
Well it does have play in the up/down side to side area. I had a similar situation in my borg warner and it ended up eating itself so I was concerned and figured I would change it out.
Glad to hear I don't have to pull the housing, that's the problem with the factory manuals, everything is written for doing it on the bench and not under the vehicle.
I would love to see a practical manual for owners but I guess that is what the web is for.
Front TC output shreik! owen Defender Technical Discussions 3 January 2nd, 2010 11:39 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
