Front Left Fog Light. Ok I need help - Defender Source
Old April 10th, 2016, 09:57 PM
GOYA
Dane McDonald
1988 Defender 90
1988 D90. Recently purchased, none of the original lights were working so I purchased an LED kit from RN, and now I only have one light not working. The front left (drivers side) fog light. It's not the light itself (I've swapped it), it's not the fuses (I've changed them), it's not the steering wheel switch (It's brand new, and the right side works). I am praying that someone has a suggestion.
Old April 10th, 2016, 10:17 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Front fog lights? Only fog lamp that's fitted to the rear, (fog guard )
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 10th, 2016, 10:23 PM
GOYA
Dane McDonald
1988 Defender 90
Running lights then? They are the top small lights on the front.
Old April 10th, 2016, 10:30 PM
roverman2010
1985 LR 90 200Tdi
If they didn'd before the change to led you have a wire loose somewhere, check the grounds are good.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old April 11th, 2016, 10:31 AM
GOYA
Dane McDonald
1988 Defender 90
I've checked every place I can find. Does anyone have a good wiring diagram?
Old April 11th, 2016, 11:35 AM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Check the ground wire leading into that light. Use a multimeter to check continuity to that ground wire and a good ground (frame bolt). Here's a 110 lighting diagram for what it's worth. Hope that helps. Your blinkers and tail light work on that side?
Name:	Screen Shot 2016-03-23 at 1.00.27 PM.png
Old April 11th, 2016, 11:54 AM
GOYA
Dane McDonald
1988 Defender 90
Both front and back blinkers work on that same side, and the ground wire to the dead light is connected to the same crimp as the front, side and rear blinker, which is why I assumed the issue had to be further up stream. But I'll go ahead and check that connection again just to make sure. This is fantastic help!
ht
LED fog lamps work lights fog lights Ben01 For Sale - Parts 2 April 20th, 2015 10:42 AM
Reverse light / fog light gremlins tim Defender Technical Discussions 10 November 1st, 2014 11:26 PM
New ROW backup light and Fog light dave_lucas For Sale - Parts 2 June 2nd, 2010 07:38 PM
Need help wiring genuine fog lamp switch and Hellas fleabus Defender Technical Discussions 1 May 21st, 2006 02:00 PM
Fog light install SFD90 Defender Technical Discussions 15 January 13th, 2004 10:51 PM
