Front hub with broken circlip/missing spacer - Defender Source
Old June 25th, 2011, 09:56 PM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
Greetings
Got into hub to repack front bearings. Upon disassembly found a broken circlip, no spacer behind it at all.
The hub nuts were also loose and the washer that was supposed to be bent was flat.
Question is. What spacer am I missing behind the circlip and how thick was it?
Where to get a new circlip and how to measure and buy the correct spacer
Any advice would be greatly appreciated.
Old June 26th, 2011, 08:39 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you are talking about the spacer, washer, that may or may not go between the clip and the hub flange then it all depends upon the play in the shaft, ,drive shaft end play,. The factory specifications should be between .08 to 0.25 MM. They have different thickness sized washers depending upon how much play you have in the shaft. I would guess that the play would depend upon the wear of the components and how stuff fits together. If the lock washer wasn't bent back then it is a good thing that you are taking care of it now.
Land Rover 110
Old June 26th, 2011, 01:30 PM
A lot don't have spacers. The lock tab a circlip are important though.
ac
Front Rotor Swap.. must break hub seal? hutch Defender Technical Discussions 9 March 15th, 2010 01:12 PM
Front Brakes and HUb Reseal bjf Defender Technical Discussions 24 December 4th, 2009 11:51 AM
Front D2 Hub for Sale RoverChic For Sale - Parts 7 June 17th, 2007 04:09 PM
front hub nut size? tkavan01 Defender Technical Discussions 11 May 22nd, 2006 06:06 PM
