Front hub seal - Defender Source
Old March 16th, 2009, 02:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
Front hub seal
To fix this leak
http://www.flickr.com/photos/barryrides/3357753737/
do I need this
http://www.roversnorth.com/store/p-5...scovery-i.aspx
Is it easy to do? will grease pour out? I don't have a clue what is i n there. Wheel have to come off?
Old March 16th, 2009, 02:42 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Maybe, though you may only need the flange gasket. Best way to make sure is pull the wheel and look more closely to see where it's coming from.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 16th, 2009, 02:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
thanks., Since the kit is only 8 bucks I might as well order it. So I have to remove the wheel to do it?
Old March 16th, 2009, 02:52 PM
bjf's Avatar
bjf
barry f
94 ST #395
Oh sorry this is for the front. The front passenger side. I do need the center cap for the one rear wheel though. Is this the same front and rear?
Old March 16th, 2009, 06:12 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Originally Posted by JSBriggs
Pull the drive flange and seal it with permatex 51813 (no paper gasket). You don't need a new hub seal unless its leaking from the back side. If it is leaking from the dust cap, use 'the right stuff'
-Jeff
I'd double check before you order, a drum Sals rear may have a different seal.
-Jeff
I second that. use permatex.... just clean everything nice first.
Legend in My Own Mind.
Old March 16th, 2009, 06:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
Any pictures of what to do?
Old March 17th, 2009, 12:35 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
You should definitely get ahold of a Workshop Service Manual.
Old March 17th, 2009, 01:01 AM
bjf's Avatar
bjf
barry f
94 ST #395
where can i buy it?
Inner hub seal seating depth KevinNY Defender Technical Discussions 32 September 12th, 2009 02:05 AM
series front hub seal airbornrover Series Technical Discussions 1 November 12th, 2008 08:48 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
