front hub nut size? - Defender Source
Old May 21st, 2006, 08:07 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
front hub nut size?
what size is the front hub nut on a d90?
I'm talking about the one inside the drive member?
if you have a rovers north catalog it's part number RNH006...
I need to pick one of these up to do a rebuild and haven't pulled apart the old one, I need to go buy a lock ring remover so i may as well pickup the "hub nut remover" as well, I don't know what the real name for those flimsy pieces of sheet metal, but i know a real socket that size is unlikely to fit inside the hub assembly.
Thanks for any input!
Old May 21st, 2006, 09:43 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hey,
You have to buy one specifically for this application. I found a cheap one made by Allmakes 4x4, part number 606435. Its real name is a hub nut spanner. I can't remember where I got it, but it was only $12 or so.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 21st, 2006, 09:49 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
Hey,
hub nut spanner, who would have thought... I guess there's no chance of finding one local on my way home from work then...
Thanks for the info, I know the nut is probably something like 2+ inches
Old May 21st, 2006, 09:52 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Not sure if there is a crossover to another make or not. I don't know the size but if you want I can put a caliper on it and get real close.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 21st, 2006, 09:55 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
looks like the nuts is 5.2 cm across incase anyone was curious
Old May 21st, 2006, 10:24 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
2-1/16" - the heavy duty one from Atlantic British works well
Old May 21st, 2006, 10:44 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
hmm thats 20 bucks and needs to be shipped from the UK, bah... at least i'll be on vacation while they ship it out i wonder if they take amex, probably not though that will make my life difficult.
Old May 22nd, 2006, 08:54 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You could use a large set of channel locks in a pinch.
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Got one from DAP, cheap. 52mm.
Old May 22nd, 2006, 09:01 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
I know, but i've torn up my dana 44 doing this, i'd rather just buy the right tool, i'm sure this won't be the last time i'm doing this.
Old May 22nd, 2006, 05:13 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I got a cheap 52mm from a local auto parts store. These nuts aren't torqued on very tight, so these hubs nuts are just sheet metal. The store had several sizes of these "truck hub nut" sockets.
Old May 22nd, 2006, 06:06 PM
These also fit ALL Jeeps to 1985 and all Scouts. It used to be the hub nut size for small 4WDs......
What size is the a-arm bolt? cbass Defender Technical Discussions 9 August 22nd, 2005 11:59 AM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Hub nut! TwisteD90 Defender Technical Discussions 22 September 28th, 2004 02:00 PM
Bolt & nut size? Berty Defender Technical Discussions 7 June 3rd, 2004 06:26 AM
