Front external shock mounting - Defender Source
Old May 5th, 2015, 07:46 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Anybody running external(outside the spring) front shocks?
I'm looking for ideas, or even better pics, of lower mount location/solution.
BTW I'm either going to modify some RRC external front towers I have, or order some of these. Ford Upper Front Shock Mount Towers Pair (E5TZ-18183-A)
Old May 5th, 2015, 08:07 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I am running the standard RRC LWB outboard front shocks....which was a PITA mounting the 300Tdi turbo pipe...
Rent my
Old May 5th, 2015, 08:10 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Any chance you have some pics of the lower mounts? Are there any clearance issues, especially on the steering side?
Old May 5th, 2015, 08:34 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Lets see---luv those Ranchos!
I think all air-suspension Classics were dampened in the front like this.
Rent my
Old May 5th, 2015, 08:38 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Thanks! No clearance issue by that nut on the panhard drop bracket?
Old May 5th, 2015, 08:53 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
as opposed to the side that doesn't steer?
Old May 5th, 2015, 08:55 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
No, there's about 1.5" clearance.
In fact, I just put those radius arms on a few months ago and dont remember any issues.
Hey smartie, this LWB is special...only steers 1 front wheel so no issues on the non-steering side. LOL
I knew what he meant...
Drop arm, panhard support thingy---
Rent my
Old May 5th, 2015, 09:03 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
You've got some smegma on your balls.
-Jeff
Just shwetty balls...
Rent my
Old May 5th, 2015, 09:09 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^^ Ha ^^
Someday I'm going to replace the inner gasket/seal...
...someday...
Rent my
Old May 5th, 2015, 10:15 PM
MudD1's Avatar
MudD1
Jeff
Hippert's 1994 D90
Old May 5th, 2015, 11:12 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Originally Posted by MudD1 View Post
Nice. So what's the bottom mounted to? Looks like it's just hanging there....
Old May 5th, 2015, 11:25 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Here's some porn from my 110 build. Qt shock mounts top and bottom, Qt radius arms, Fox 2.0 remote res shocks. The shock reservoirs will likely move to the actual upper shock mounts as I think they'll hit the inner fender in this configuration.
Lower shock mount bolts to the radius arm mounts on the axle.
ID:	120069   Click image for larger version
Semper Fi!
Old May 6th, 2015, 10:47 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Some quick pics
ID:	120080   Click image for larger version
Old May 6th, 2015, 10:52 AM
Dumb question... Why do it this way? Edumucate me
95' D90 - daily driver..
Old May 6th, 2015, 11:13 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
More potential for articulation as well as easier access to everything, quicker installation, ,more options for cones/retainers, more shock options, etc. Lots of reasons.
Mark, why'd you end up with regular 7100s instead of short bodies?
Old May 6th, 2015, 11:29 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
So where'd you find the QT stuff? Those parts look brand new but I couldn't find either the towers or lower mounts on their website??
Thanks for all the pics guys! I should be able to fab something up for my front axle now that I've got a good idea where everybody else is mounting theirs.
Old May 6th, 2015, 12:25 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
They are sb. 14"
Old May 6th, 2015, 12:27 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
haha damn, that is impressive. I've never seen 14s in the front of a Defender. Any photos of the droop?
Old May 6th, 2015, 12:30 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
All three of those pics are front end shots. It will go further with my 35s on there. I also have a 3 link I may be putting in soon.
Old May 6th, 2015, 06:05 PM
Wolf Fabrication
Sterling Archer
'08 D3
So where'd you find the QT stuff? Those parts look brand new but I couldn't find either the towers or lower mounts on their website?? Thanks for all the pics guys! I should be able to fab something up for my front axle now that I've got a good idea where everybody else is mounting theirs.
I got the last ones. Qt was bought by Wildcat.
All my rear suspension is Qt as well. I have mounts that move the shocks inboard of the frame and slant in as well.
The below is not my truck, but shows my setup.
Semper Fi!
mount
Front external shock mounts Jake1996d1 Wanted 1 November 26th, 2012 05:30 PM
Front external shock mounts? PCRover Defender Technical Discussions 17 April 1st, 2010 11:36 AM
External Front Shock Mounts WhiteD90 For Sale - Parts 0 June 5th, 2008 09:58 PM
External front shock mount ini88 Wanted 0 March 25th, 2007 11:12 PM
external front shock mounts? brianbonner Defender Technical Discussions 9 January 11th, 2005 05:06 PM
