Front external shock mounting - Page 2 - Defender Source
Old May 6th, 2015, 06:09 PM
Holy crap that's some serious articulation
95' D90 - daily driver..
Old May 7th, 2015, 04:51 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Originally Posted by Arcadeus View Post
Some quick pics
What kind of Springs are these? Who makes them?
Old May 7th, 2015, 04:55 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Those are RTE... I have the same and they're excellent springs
Old May 7th, 2015, 05:12 PM
mounted my fronts externally recently:
http://www.defendersource.com/forum/...ngs-60472.html
Old May 7th, 2015, 05:17 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I have RTEs too and they are not as long as that. Are those the old springs they used to make that were really long and allowed you to not run a cone?
Old May 7th, 2015, 05:38 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
They are progressive rte. bought them new about two years ago.
Old May 7th, 2015, 05:58 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
They ride great, I got mine March last year, so they're not the older style. I run cones and retainers.
Old May 7th, 2015, 06:07 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Yah wish they were a bit longer but then they limit compression. All in all they are a good compromise.
Old May 7th, 2015, 07:39 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I remade mine like this as they were the same as the Qt ones on Wolf's truck as I wanted them double shear on the bottom, I did them as single shear at the time to use easily available parts in the UK. I could be persuaded to make some tops as I have all the drawings still.... wouldn't be BZP though...
This is the sort of flex you'll get but as noted it's all about compromise.
I swapped my upper mounts to these as they now tie into the front h/d wings
Old May 7th, 2015, 09:17 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Wow Andy....damn.
Old May 7th, 2015, 10:29 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Wow Andy....damn.
Andy is my favourite dealer of rover porn!
Old May 8th, 2015, 07:26 AM
Cube II's Avatar
Cube II
Michele
1997 D90
How did you solve the issue?
I have too the RRC external mounts which I'd like to use, but eyeballing I'd say the mount would collide with the intercooler hose.
I am running the standard RRC LWB outboard front shocks....which was a PITA mounting the 300Tdi turbo pipe...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old May 11th, 2015, 07:58 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Shock bolt mounting orientation?
Parallel with the axle, or parallel with the frame rail? Which at the top, which at the bottom? Does it matter?
I'll be running Fox shocks with polyurethane bushings, not heims. I'm looking to get rid of as much bushing bind as possible.
Old May 11th, 2015, 08:11 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Parallel with the axle... For both... Helms wear out too fast... I switched to bushings as well...
Old May 11th, 2015, 08:21 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Michele, I just made a custom pipe that had a 90 degree bend to drop down past the top of the shock mount to the bottom of the intercooler.
Rent my
Old May 11th, 2015, 08:36 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
That doesn't cause a lot of stress/binding on the bushings under articulation?
Old May 11th, 2015, 08:41 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
It does... But most of the movement of the axle will still be compression or droop... The axle swings in an arc and the shocks need to shift to follow it... The bushings should allow enough side to side shift...
Old May 12th, 2015, 04:29 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Errrr...do you have a photo?
I thought of opening a small window in the mount to leave the hose some room,
but I don't want to weaken the mount...I need to have a look at the whole thing once again, hopefully this spring summer.
The Cube is away at the moment for other works and won't be back for another two weeks I fear...ouff...
Michele
D90 VNTdi
[O]===[O]
mount
Front external shock mounts Jake1996d1 Wanted 1 November 26th, 2012 05:30 PM
Front external shock mounts? PCRover Defender Technical Discussions 17 April 1st, 2010 11:36 AM
External Front Shock Mounts WhiteD90 For Sale - Parts 0 June 5th, 2008 09:58 PM
External front shock mount ini88 Wanted 0 March 25th, 2007 11:12 PM
external front shock mounts? brianbonner Defender Technical Discussions 9 January 11th, 2005 05:06 PM
