Front End Shimmy - Page 2 - Defender Source
Old October 3rd, 2005, 07:36 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Mike, Thanks for correcting me on the pinion/swivel. You're right, I was talking about the swivel.
I pulled out the driveshaft and drove around. Exact same symptoms. (I guess that rules out loose driveshaft bolts and U-joints)
Jacked the front end, and with selector in neutral, turning one wheel one direction causes the other to turn in the opposite direction. No grinding, clunking.
Turned the front wheels as if steering (with truck jacked up) and didn't feel any play in the panhard rod bushings. Would I only recognize play in those bearings if I was steering from the driver's seat rather than turning the wheels by hand?
How could I recognize failed CV joints?
Old October 3rd, 2005, 07:56 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
To properly check the panhard rod bushings is a two person job. You need to be under the truck visualy inspecting the bushing while someone else turns the wheel. You will see the bolt move inside the bushing before the rod starts to move. Dont jack up the front end when you do it, having the resistance of the wheels on the ground will make the bolt movement in the bushing more exagerated. If the bushing is only mildly shot, having the truck jacked up may make it hard to identify the suspect bushing due to the low resistance.
Good luck.
Kevin
Old October 3rd, 2005, 09:04 PM
Kevin has the bushing checking meathode down good But if you don't have 2 people try tightening all the bolts, sometimes they work themselfs loose. But if you can get someone to turn the wheel back and forth, look at every connection point, look to see that the wheels are both turning at the same time. Also put a wrench on the upper radius arm bolt and give it a twist back and forth, it shouldn't move very much at all.
Most of the time CVs click when cornering if they are bad. When you turned one wheel and the other turned the other way that means the diff is open (not locked) and working.
Old October 3rd, 2005, 09:38 PM
loykd's Avatar
loykd
Ken Loy
Got some help with the turning the steering wheel and the panhard bushings, both ends of the panhard rod, are tight. No movement at all. All the other bolts seem tight as well.
I don't notice clicking when turning.
I have previously bent the track rod and did my best to bend back into shape. It's been rubbing against the guide on the back side of the differential. I removed the guide and it's riding a bit more smoothly. I think I'll play around with the alignment tomorrow, maybe even take someone's original advice and have the tire balanced....
Any other ideas?
Old October 3rd, 2005, 09:42 PM
Swap out with the spare tire if it might be unbalanced. Are the tires both turning at the same time?
Old October 4th, 2005, 08:58 PM
scoloco's Avatar
scoloco
'94 D90 ST
Try putting the front tires on the back and back tires on the front. Does the vibe move to the back?
If you did lose a weight, how would you know??? I dont believe there will be a mark or any other indication that it was attached. Just another thought.
Old October 10th, 2005, 10:03 PM
loykd's Avatar
loykd
Ken Loy
Success! And I learned a ton from the whole troubleshooting process.
And the winner is.....JP, with honorable mention to Kelly. It was the REAR driveshaft u-joint. Mechs at Roverland (on Eisenhower in Alexandria) helped me diagnose. Good to have a pro.
I've always been thinking that the vibes were coming from the front, but in fact they were in the rear and were being transmitted all the way forward, and felt in the steering. I pulled the front driveshaft, but should have pulled the rear too and I would have found the real cause earlier. (and avoided unnecessarily replacing the front wheel bearing) Never would have thought that myself, and should have listed to JP.
One other thing I'd offer as advice: if you're replacing brake rotors, replace the bearings at the same time. As long as you're there, it's not that much more time (and the cost of the bearings aren't that expensive).
Old April 11th, 2006, 11:08 PM
bbandit
William Baker
1997 Defender 90
I just had the panhard rod bushings replaced on my 97 d-90. wobble is gone. I would guess that's what our problem is also.
Tilting Front end Feraltracker Defender Technical Discussions 20 November 26th, 2017 10:40 AM
Front End Shimmy bbandit Defender Technical Discussions 19 April 11th, 2006 11:06 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
