Front end caster adjustment - Defender Source
Old January 14th, 2016, 01:33 PM
Does the 95 have a way to do it. The alignment shop is stumped on this (not sure if it's needed yet)
95' D90 - daily driver..
Old January 14th, 2016, 01:36 PM
There is no way to adjust castor. Toe is the only adjustment.
It decreases with a spring lift. There are a few modifications available to increase it, if you want.
Old January 14th, 2016, 01:52 PM
We decided it is good enough, aligned straight and just tightened it up.
Next time I'll just use string in my garage as that's how they ended up doing it.. The hunter machine was pretty much useless.
Old January 14th, 2016, 02:29 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
In order to adjust caster you have to modify the swivel balls.
Mark G handle ezzzzzzz is setting his mill up to do just this.
Jig is built... think he's just now working out the formula for precision.
RDavisinVA
Old January 14th, 2016, 02:35 PM
How do people who are supposed to be experts at alignment look at the front end and then ask how to adjust the castor? Personally I would see that as a red flag right there.
Old January 14th, 2016, 02:37 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Rob where did you take it? I go to McNair Performance when I get my vehicles aligned. Ive been wanting to try the "String" method though.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old January 14th, 2016, 02:39 PM
There is zero reason to go anywhere near an alignment machine unless you think you have a bent axle. It is simple to do yourself.
Old January 14th, 2016, 03:57 PM
Brakes plus on jones Franklin they are small and Indy, they didn't charge me since they didn't really do anything.
String seems the way to go from here on out as you only have one adjustment anyway.
GBR axles, caster correction balls and flanges waggoner5 For Sale - Parts 10 April 8th, 2012 06:25 PM
Caster Correction Kit ]-[ @ n $ Defender Technical Discussions 5 October 24th, 2011 11:10 PM
How do Caster Corrected Front Radius Arms Help? IPSC_GUY Defender Technical Discussions 14 May 5th, 2010 11:06 PM
Camber/Caster... can they be modified?? B-Kerr Defender Technical Discussions 2 June 21st, 2005 11:22 PM
WTB - Caster corrected radius arms Tawayama Wanted 4 February 12th, 2004 12:35 AM
