Front Driveshaft Bolt Orientation - Defender Source
Old May 20th, 2013, 01:11 PM
Grover's Avatar
Grover
Question Front Driveshaft Bolt Orientation
Is there any reason the bolts fastening the front driveshaft to the T/C output yoke are oriented with the bolt heads facing the T/C?
In order to replace the bolts, the output yoke has to be removed.
Cheers...
Old May 20th, 2013, 01:33 PM
I don't think there is space for nut on the TC side.
Old May 20th, 2013, 01:58 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
This and there may not be enough room for the bolt to protrude through the nut.
Old May 21st, 2013, 09:51 AM
Try reversing them and let us know what you find out.
Old May 26th, 2013, 01:18 PM
Grover's Avatar
Grover
Thumbs up
Reversed them, no problem.
The reason for the question...I was removing my front ds and one of the bolt threads was stripped from the output yoke side. This may have happened when built 18 years ago. He bolt was only snug, the other three were incredibly tight.
Removing the stripped nut was not that difficult...just drilled the sides out a 180 degrees apart, then split in half. The inside threads of the nut were nearly gone, I'm supprised it lasted as long as it did...
I removed the output yoke in hope I could remove the said bolt...but the mud shield was in the way. So, I carefully cut the bolt heads off and re-installed new bolts with the heads facing forward.
All is good...
Cheers...
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
ss bolt kit installation question geneseemtn Defender Technical Discussions 2 December 4th, 2005 12:28 PM
new front driveshaft for sale Chris Cox For Sale - Parts 3 February 27th, 2004 10:24 PM
disco 2 front driveshaft jperakis Wanted 0 January 29th, 2004 02:24 AM
