Front drive shaft play - Defender Source
Old September 19th, 2012, 02:52 PM
doscazadores
Vic Stull
none
I can rotate the front drive shaft ('95 D90 ST) by hand quite a bit; maybe 3/8"+. Rear shaft, not at all. Should I be concerned? What is the likely answer to why this is happening? Thanks, Vic
Old September 19th, 2012, 03:39 PM
No concern. I assume you have the truck in park or the parking brake on which is locking the rear shaft. The play in the front diff and diff in the t-case have about that much play. Unless it is loose at the splines or at the u-joints on the driveshaft, it is completely fine and normal.
Old September 22nd, 2012, 12:40 PM
doscazadores
Vic Stull
none
Originally Posted by evilfij View Post
No concern. I assume you have the truck in park or the parking brake on which is locking the rear shaft. . . .
Uh, well, . . . duh.
And thanks.
Stock front drive shaft length? D90user Defender Technical Discussions 4 September 29th, 2009 02:46 AM
REBUILT FRONT DRIVE SHAFT $100 shipped RoverDude For Sale - Parts 6 July 13th, 2009 07:40 PM
Used rear drive shaft dmarchand For Sale - Parts 0 October 15th, 2004 11:30 AM
front drive shaft jorge Defender Technical Discussions 6 December 9th, 2003 11:23 AM
