Front door window alignment - Defender Source
Old September 16th, 2016, 02:48 PM
GrizzlyChicken's Avatar
GrizzlyChicken
Shane Munro
2001 Land Rover Defender 110
Hi Guys,
So Im new to this forum. Just bought a 2001 110 td5 and starting to look at fixing it up a bit. The first step is to have it pass a roadworthy, MOT, out of Province inspection. One issue that was identified is that the window on the passenger side (left hand drive) does not fully go up.
Taking a look at the door, it looks like the top of the door frame (window section) may have been bent in a rearward direction sometime causing the window to hit at the front and stop it from going up at the back.
Suggestions for a fix? I was thinking of getting a block of wood in the front upper corner and hammering on it in a frontward/upward direction to bend the frame back. Just wondering others thoughts or experiences? Should I heat the frame? woried it may blister the paint if I do.
I have attached reference pics.
thanks for any help!
Shane
ID:	157730   Click image for larger version
ID:	157732   Click image for larger version
ID:	157734   Click image for larger version
Old September 16th, 2016, 03:45 PM
Hammer and wood ratchet strap prybar jack etc. evilfij approved.
Old September 20th, 2016, 10:19 AM
GrizzlyChicken
Shane Munro
Awesome Thanks!
Think I might try a jack diagonally across the window braced with a 4x4 in one corner and 2X4 in the other. Need to shift the top front corner forward.
window, alignment, door
Door and Bulkhead alignment sflash868 Defender Technical Discussions 5 April 30th, 2016 09:06 PM
fiberglass hartop & door alignment Rufus Defender Technical Discussions 5 February 8th, 2013 07:47 AM
Door alignment, adjustment question jayz Defender Technical Discussions 10 July 23rd, 2012 11:07 PM
Front Door/Rear Quarter Panel Alignment Grover Defender Technical Discussions 12 August 7th, 2008 06:22 AM
Bonnet / Hood alignment jcasteel Defender Technical Discussions 1 November 6th, 2004 09:07 PM
