Front Differential is full - Defender Source
Old September 5th, 2011, 12:57 AM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Is this because of a worn seal at the swivel ball?
Any tips on fixing it?
Old September 5th, 2011, 07:37 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
They are supposed to be full. At least full up to the fill plug.
But I'm thinking you must mean something else.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 5th, 2011, 09:50 AM
loykd's Avatar
loykd
Ken Loy
Yeah, they're full, above the fill plug. I see sludge around the left swivel, and that makes me think that the problem is there.
Old September 5th, 2011, 10:32 AM
ken
are the swivels full also?
does the diff oil look normal?
have you been driving in water?
Old September 5th, 2011, 11:11 AM
loykd's Avatar
loykd
Ken Loy
it doesn't appear as the the swivel has oil. the diff oil looks normal. i.e not milky or excessively dirty. and um.. no, haven't been driving it in water.
Old September 5th, 2011, 01:11 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Were you the last one to fill the diffs? Did you do it on an incline?
After it's been sitting overnight open the drain plug a little and see if water or gear lube comes out.
Are you running oil or grease in your swivels?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 5th, 2011, 01:15 PM
loykd's Avatar
loykd
Ken Loy
I filled them last, and yes, it was flat. No water in the diff oil, it appears. oil in the swivels.
Old September 6th, 2011, 11:25 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Ken, have you increased the lift on your truck since the last change? My diffs seem to be tilted back as a result of a 2 inch lift and it bothers me that i can't get more oil in without jacking one end or the other to compensate.
Old September 6th, 2011, 12:27 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
You don't have to jack it up to fill the diffs once the rig is lifted...just fill through the vent hole once you've topped it up through the fill plug.
Old September 6th, 2011, 01:00 PM
Ken, nice to see you are giving her some TLC! I read this thread but things don't add up. Post a picture of this sludge you see if you want, otherwise I say just drain and fill both the diff and the swivel balls - i know your truck has been sitting long enough that it wouldn't hurt. Then check it in a few weeks parking back at the same spot/incline. Unless the oil looks odd, you should be fine and there is nothing to worry about.
charles
Originally Posted by pendy
I'm here for the D's
differential
Trouble removing front differential chris snell Defender Technical Discussions 15 February 21st, 2010 09:18 AM
FREE: D90 Front Drive Shaft and Differential Guts coryhula For Sale - Parts 3 January 6th, 2009 03:54 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
» Defender Registry
94 D-90
jkins
D
drsmiley
Add your Defender
