Front diff issues - Defender Source
Old October 9th, 2013, 03:28 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Front diff issues
So I already posted that I'm looking for a new front diff, but I wanted to post 2 videos of how its currently working.
It looks like the carrier (Trac-lock) is stuck locked and the passenger side axle splines mostly stripped on the diff side.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 9th, 2013, 04:30 PM
Danny, pull it and you will know exactly what's wrong. You have to pull it anyway!
Originally Posted by pendy
I'm here for the D's
Old October 9th, 2013, 04:34 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Haha. Its on the list! Im trying to secure a way to get to the train for the next few days/week. Just figured I'd post the video.
~2008 GTI TSI
Old October 9th, 2013, 06:25 PM
Have you pulled it apart to actually see? What makes you think the splines are stripped?
Before you go buying a diff, take everything apart and see what is actually broken.
Old October 9th, 2013, 07:15 PM
Could be broken at the CV. You need to pull the right side and see what you find. You sure it is not just the drive flange splines? It is very doubtful you would have stripped it at the diff or damaged the diff.
Old October 9th, 2013, 07:25 PM
Danny,
Have you pulled the rubber dust boot and removed the snap ring to look @ the drive flange ? Takes 2 mins.
As I was saying @ the Cove I have stripped several of them out. They are soft cast iron and as it was explained to me they are the "fuse" in the drive train, ie designed to strip out easily. Many say too easily.
They are cheap too.
Old October 10th, 2013, 04:38 PM
ashtrans
Dave Ashcroft
Danny,
They are cheap too.
Yep, pop the rubber cap off, I bet the drive flange splines are stripped
Dave Ashcroft
Old October 13th, 2013, 02:55 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Danny,
They are cheap too.
Thanks for the help everybody, I pulled it apart down to the hub nut (then realized i didn't have the hub nut tool). I'd tap it off with a hammer and screwdriver but then i'd be hesitant to re-use it. Ordering that this week, going to have to try again next weekend. Video below shows the drive flange...
~2008 GTI TSI
Old October 13th, 2013, 06:17 PM
A punch would be better than a screwdriver, but even then, its OK to reuse, so long as you don't mangle it. You can reuse the lock washer if you hammer it flat while its off.
Its 2-1/16" but 55mm (Toyota size) will work as well, and is usually available at the local Vato-zone.
-Jeff
Get this:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
And these:
http://www.lrseries.com/shop/product...D100000&page=1
Old October 13th, 2013, 07:26 PM
Broken CV my friend.
Old October 13th, 2013, 09:34 PM
agreed
Old October 13th, 2013, 10:25 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Call Will Tillery as soon as you verify that it is in fact a broken CV.
Last time I was at his shop he was tripping over all the CVs and axles aging around...
Rent my
Old October 15th, 2013, 02:24 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Oh and btw Danny,
If you need to go cheap, get yourself a RoversNorth Hub socket.
http://landroverparts.roversnorth.co...D-STEEL&key=it
You can use a long screwdriver or bar or mod it.
I welded an old 3/8 socket on a piece of scrap metal to make mine ratchet driveable.
The stamped socket is very strong; I've been using this one since 2002.
Rent my
Old October 20th, 2013, 03:49 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Pulled the wheel->hub->stub axle->CV and voila, there's a broken tab and one of the ball bearings was floating around in there. I cleaned out the swivel but can't seem to find the piece of metal that broke off however... I'm hoping its either pulverized from driving around in there, still stuck in the CV itself or inthe mess of grease goop that poured out.
see pics below.
One thing to note, the splines at all ends of the axle look fine.
ID:	82441   Click image for larger version
ID:	82443   Click image for larger version
~2008 GTI TSI
Old October 20th, 2013, 04:11 PM
Danny. Nice chatting with you. The part that is cracked is the "star". Very common failure. Keep whacking the cv until it comes off the shaft then check the splines as we discussed. Call me again if you need more help.
Old October 20th, 2013, 06:08 PM
-Jeff
That is what I meant.
No matter, he needs a new CV and needs to check the splines.
Old October 21st, 2013, 09:14 AM
And I am sure you know Randy Williams is close to you as well. I'm glad you took the time to investigate before getting a diff.
Old October 21st, 2013, 01:52 PM
I have some surplus CVs Danny, send me a PM or gchat.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old October 28th, 2013, 11:51 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
got the axles/cvs from DB last weekend. I'll post how the reassembly goes
~2008 GTI TSI
Old November 9th, 2013, 03:47 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
All back together. CV was the problem. No more grinding and I have drive with the CDL unlocked again.
Thanks everybody for your help.
~2008 GTI TSI
front and rear diff guards.. the rover shop For Sale - Parts 5 June 27th, 2012 12:52 PM
Front diff flippedrover Wanted 11 October 29th, 2006 09:10 AM
Front diff going jdb3760 Defender Technical Discussions 6 May 15th, 2006 02:29 AM
Any opinion on QT services Diff protection? COSteve Defender Technical Discussions 21 October 28th, 2004 06:17 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
