Front D-Shaft Likes to do the shimmy - Defender Source
Old April 15th, 2006, 03:56 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I am getting driveline vibes between 40 and 50mph during acceleration. I have a new GBR double cardon shaft and the SG 3 link with it setup to point the pinion almost in line with the shaft so the angles are the same. What gives. I removed the shaft just now and its smooth sailing..
Legend in My Own Mind.
Old April 15th, 2006, 04:47 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I hate to say it but pull the drive flanges & have the whole thing balance together.
If I remember correct my pin angle & ds angle are 3 degrees off. if that helps
Old April 15th, 2006, 05:01 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Thats what I was thinking of doing since its off. I guess even a new d-shaft could be out of wack.. And I guess thatwould give me the shakes. I played around a lot with the angle thinking that was it but no matter how I put it, It still vibes..
Old April 15th, 2006, 05:03 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Its not so much the shaft as the flanges. Once balanced as a whole mark em!!
Old April 15th, 2006, 05:07 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
YOu mean the flanges on the t-case and the diff?
Old April 15th, 2006, 05:13 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Correctamundo! My ds guy does the whole shebang.
Old April 15th, 2006, 07:39 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Wow. Never heard of this before. I will have to check it out. Should I first just bring the shaft and see if its Fu&%ed up?
Old April 15th, 2006, 10:04 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
You know its worth a shot. I would call my local driveline guy & see what he says. I did not do both flanges only the tc side. I was worried about loosing pinion preload.
did you line up the marks that bill has on the adapter & ds? I am sure you did.
is the noise different on acc or dec? perhaps a differential noise?
I hope a balance job does the trick..
Old April 16th, 2006, 07:22 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Actually Pete, I did not line up anything. There are marks on the adapter and ds????
I actually only get the vib during harder acceleration. I guess when there is more of a load on it.
Where would the marks be for me to look at this...
Old April 16th, 2006, 11:00 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Well there should be a V on the adapter & shaft [those need to line up]. This is how the shaft was balanced.
I am thinking I have never had a shaft vib under acc. Could you have a ring gear preload issue?
Before you flip find the marks on the shaft if they are lined up well you need to dig more.
Old April 16th, 2006, 02:31 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will reinstall with the V lined up. I just found the marks. I doubt they were...
Old April 16th, 2006, 03:57 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Let us know if that fixes it. I doubt it will. If it is happening under acceleration, chances are your pinion is pushing upwards. There might be something loose on your 3-link.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 17th, 2006, 01:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
So far so good. I drove it to work this morning and it seemed fine. When I had it off I also noticed a lot of mud caked inside the adapter and all the bolt holes which might have thrown things off too.
I reinstalled it with the V marks lined up also this time..
Old April 17th, 2006, 01:31 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Glad to hear it!! One less thing to worry about.
Old April 17th, 2006, 07:51 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yup.. seems to be fine. No vibes..
Old April 17th, 2006, 09:08 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Front End Shimmy loykd Defender Technical Discussions 27 April 11th, 2006 11:08 PM
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
D11 front drive shaft jorge Defender Technical Discussions 3 April 12th, 2005 08:03 AM
front drive shaft jorge Defender Technical Discussions 6 December 9th, 2003 11:23 AM
