Front crank seal R&R Qs - Defender Source
Old June 21st, 2015, 08:35 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
Have a slow weep keeping the weep hole moist at the timing cover. PROBABLY the crank seal.
Before I tore it apart and got into that, I wanted to make sure I had what looks like a simple procedure straight.
I've replaced the timing belt before, so I know my way in ok.
I've looked through the overhaul manual. Seems straight forward.
Do I need a puller to get the timing gear off the crank? I can probably/maybe produce one that would work, but i don't remember needing one before. If needed, any particular type? Will a pulley puller do?
Once I get that off, its a simple prise out the old seal and drive in the new lubricated one right? just like the rear main?
Thanks anyone that can help. I don't want to start into something and leave my vehicle disabled for an extended time getting parts/tools.
Must replace R380 Fork - Do the clutch & rear seal too? Landspeed Defender Technical Discussions 3 May 25th, 2012 04:36 PM
Crank shaft Seal Zooben1 Defender Technical Discussions 3 May 18th, 2011 09:56 PM
200tdi rear crank seal D90user Defender Technical Discussions 3 March 23rd, 2011 02:50 PM
front cover, crank driven oil pump with distributor Davis Defender Technical Discussions 11 March 20th, 2010 12:52 PM
rear hub gaskets, Right Stuff & seal direction cdb Defender Technical Discussions 4 May 31st, 2009 12:01 PM
