front cover, crank driven oil pump with distributor - Defender Source
Old March 19th, 2010, 04:25 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Does anyone know the part number for the interim front cover that has the crank driven oil pump WITH the distributor hole drilled?
Old March 19th, 2010, 05:36 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
http://cgi.ebay.co.uk/Timing-Cover-L...item230609bfd6
This item on eBay? Part Number HRC 1321
Firemanshort
1980 Stage One 109
Sterling, VA
Old March 19th, 2010, 06:46 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Wrong cover in the e-bay ad there.
He's looking for the one from the 95(?) discoveries that had serpentine belt 4.0's, but still had a distibutor and the Hot-Wire EFI like the 94/95 D-90's.
Unfortunately, I don't know the part number.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 19th, 2010, 08:08 PM
Why? Whats wrong with dizzy drive?
------ Follow up post added March 19th, 2010 08:09 PM ------
-Hans
No 4.0 had a dizzy
Old March 19th, 2010, 09:06 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
A lot of early range rovers used this. It is called an interim front cover and operated primarily with the hot wire. I am debating using the crank driven pump due to its much higher volume and converting to serpentine but I am not willing to give up a v-belt set up unless I can figure out my York air compressor which I love. I figure I can figure out how to mount a york on a serp belt set up. And if so, I am probably switching.
Old March 19th, 2010, 09:51 PM
more volume from the crank pump ive never heard this, I never hear about the dizzy drive failing. Only advantage to the serp is the GM fan clutch period.
Old March 19th, 2010, 10:15 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
The motors that used this interim setup had the older style short snout 3.9 crank but a longer key way (vs the long snout 4.0 crank). Pretty much have to remove the crank and machine the key way longer as the short version does not fully engage the oil pump. Not doing so will seriously risk pump failure. I did a bunch of these at one point but the novelty wore off. I have the part #'s (and probably the covers) at the shop.
Matt Browne
Old March 19th, 2010, 10:44 PM
Hans's Avatar
Hans
Hans Haase
No 4.0 had a dizzy
Ok, then it was the GEMS 3.9's with serpentine cover and distributor's. Either way, there was a front cover that used both the rotary vane pump and distributor. And it was, as far as I know, only seen in the '95 NAS Disco's.
Mike Hippert did a conversion a few years ago using this method in his defender, and posted it up here. He used a 4.0 long block, with the distributor/serpentine front cover, and a 3.9 intake plenum. It's an interesting thread to read through.
http://www.defendersource.com/forum/...ead.php?t=5560
The big improvement is that you get a lot better oil pressure out of the 4.0 style rotary pump as opposed to the ancient external gear pump of the 3.9's. You would be surprised how low the pressure is with the older style pumps.
-Hans
My oil line fix
Old March 20th, 2010, 12:04 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Folks--When using the interim front cover, it requires the longer keyway. Please correct me if I am wrong, but I already have that with my 4.6l crank, right? Therefore, using the interim cover, you have to have a hotwire set up running a distributor but it uses the crank driven oil pump that does increase the capacity of the oil pump by over 20%. If you ever want a history in the Rover engine, especially in relation to the various front covers, styles of ECU, ect, ect, get the book called How to Power Tune Rover V-8 for Road & Track by Des Hammill. Awesome book, tons of info, covers 3.5 - 4.6.
That said, still trying to find the part number for the interim cover, if you have it.
Old March 20th, 2010, 12:11 AM
It is the cover used on 94-95 DIs and 1995 RRCs.
Crank driven pump with a hole for the dizzy. $570 from AB. I might have a used one, but I am not digging it out. It will work with a 4.6 block. Probably can find used cheap and they really don't go bad often.
Engine Front Cover
Item: ERR6814GGenuine Part In Stock: Yes!
Fits:Discovery I | '94 - '95 | Fits 3.9 engine only
Range Rover Classic | '95 | Fits 3.9 engine starting with engine number 36D25155A and 4.2 engine starting with engine number 40D09582B
edit: at least this is what I think you are talking about.
Old March 20th, 2010, 07:19 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Davis, you are correct that you have the long snout crank on the 4.6 so you are OK.
part # is ERR6814. (please check that is correct if ordering.....should be for a '95 Disco 3.9 or 95 RRC 4.2)
Beware of used front covers, these pumps do wear and if you've ever taken one apart and looked you'd be surprised. You can replace the pump gears but the cover is the part that wears so you are really not achieving anything.I have never seen real improvement in oil pressure by swapping to the newer style pump, in general it is about the same improvement as rebuilding the old style pump.
Also with these covers be VERY careful when installing the oil cooler lines. The cover itself is very tender at the oil filter oil line junction and if you take note of the factory torque settings for these lines they are very low (I can't remember of the top of my head, but is not much over finger tight) and if over tightened at all will crack the cover rendering it pretty much useless.
Matt Browne
Old March 20th, 2010, 12:52 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Thanks everyone for your advice and pointers--very appreciated!
cover, distributor
Lining up distributor and oil pump shaft sflash868 Defender Technical Discussions 2 November 5th, 2007 08:15 AM
Oil pump will not prime... greend90SW Defender Technical Discussions 8 April 13th, 2006 08:46 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
