Front cover? - Defender Source
Old May 9th, 2005, 12:44 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Front cover?
What is Locktight 572? That is what my man. says to use on the FC bolts. What do you guys use?
Old May 9th, 2005, 12:52 PM
I don't recall the manual saying to use any loctite on the front cover?
http://www.loctiteproducts.com/produ...id=10&subid=48
Old May 9th, 2005, 12:55 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
It is for the bolts?
Old May 9th, 2005, 12:58 PM
Yes loctite is a coating you put on the bolts to keep them from backing out due to vibration. But I have recently been doing some work on the front cover and I don't remember having to coat the bolts with loctite.
Old May 9th, 2005, 02:50 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Mike do you use anything on the gasket ie. haylo hi tack ect!
Old May 9th, 2005, 03:01 PM
I'll look tonight but I think you need to put some around the water passages. I use great stuff.
Old May 9th, 2005, 05:33 PM
Your right, you do need loctite, an auto parts store should have it, I am not sure if they are labled what type they are (527) but they are marked for the size of the bolt. Now it also says to use loctite on the long water pump bolts, everyone that I know that does this coats the bolts with right stuff and not loctite because it seals the bolts up better. Doesn't say anything about using sealant on the gasket, I can't see it hurting to use it but I wouldn't worry if there the joining surfaces are both smooth.
Old May 9th, 2005, 05:45 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Really? We're supposed to use a threadlocker on it? Never put any on mine, will check those bolts soon. I used anti-sieze but not a threadlocking type.
I used one of the brush on type hi-tack gasket sealants, worked great. I hate the tubed stuff.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 9th, 2005, 05:51 PM
The book says too but when i pulled my bolts they didn't have any, they are also only torked to 28 nm, thats nm not ftlbs, not very much tork there.
Old May 9th, 2005, 06:00 PM
Hans's Avatar
Hans
Hans Haase
Mine had anti-sieze on the header bolts already when I had to remove them, very glad about that too... I hate header bolts and was paranoid about them being very stuck. I WISH they had been on my intake plenum, they were all siezed between the head of the bolts and the upper plenum. Thankfully I only had to cut off 1 of them.
-Hans
My oil line fix
Old May 9th, 2005, 07:07 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
My oil pump bolts were all seized.soaked 3 days in pb & heat didnt faze. Drilled them all & only buggerd 1 a little. I am going to use the blue thread locker & pfe to seal the wp bolts.
Old May 9th, 2005, 11:26 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Some of the waterpump bolts are not into blind holes and actually penetrate the water jacket. I believe Loctite 572 is pipe thread sealant (White). That is what we always use.
Rob
Old May 10th, 2005, 03:26 PM
Rob is correct.
cover
Seat Cover (for front seats) wilson5225 Wanted 0 August 19th, 2009 10:43 PM
Front Tunnel Cover JPRO576 Wanted 15 April 24th, 2009 12:36 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
FS: D-90 Parts (Bikini Top, front bumper, wagon seat back cover, shift lever bezel dzientek For Sale - Parts 5 March 16th, 2005 12:09 PM
