front caliper brakeline - Defender Source
Old November 4th, 2004, 10:52 AM
jabber
m j
110
Strange thing these D90s.... I'm was in the process of disassembling the front end and noticed a small brake line jumper from the flexline to the caliper. To remove the caliper I had to disconnect this line. Well since I have a 94 she was pretty rusty; needless to say I now need to replace them.
My thought is, why not just connect the flexline directly to the caliper? I know I'd need some sort of adaptor, to change the size....
If i need to replace it, is this a custom bend or can this be purchased?
I'll try and get some pics up tonight.
Cheers,
jabber
Old November 4th, 2004, 11:06 AM
You can try to fab your own by recycling the fittings and flaring the ends yourself. Tubing is available at napa. Problem is with that little tube is that the bends are really tight and hard to form. The line doesnt cost that much (probably under 25) so Id call RDS and see if George has one in stock.
Old November 4th, 2004, 11:57 AM
I think Dave Merchand replaced his lines with stainless steal lines from East Coast Rovers.
Old November 4th, 2004, 12:45 PM
Actually, I did that too - they are beautiful pieces of work. I just didnt want suggest the 325 dollar option for replacing a single line
Old November 5th, 2004, 08:16 PM
ToaDisco
Thomas Abernethy
If I am reading this correctly, I broke the same hard line. It was a major PITA to find one, and I eventually went to the dealer and they ordered one. I thought I was going to be raped but it turned out to be only around 10$ per line, so that is a pretty decent option if you choose to keep the solid brake line.
Old May 3rd, 2009, 11:31 AM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I converted my rear axle to a Disco 1 one when I did my toyota conversion and now it has sway bar mounts that the original axle didnt have. Do you think it would be better to get a new hard brake line or just cut off the sway bar mounts? Thanks
ID:	19255   Click image for larger version
brake
Front left Brake caliper tomaco1 Defender Technical Discussions 5 October 17th, 2008 07:36 AM
Range Rover Front Brake Caliper Question TDI Guy Misc. Chit-Chat 10 May 24th, 2006 08:14 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
