Front brakes axle shims won't fit... - Defender Source
Old June 6th, 2006, 01:26 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
OK, so I got one of the front rotot hub bearing assemblies back on (DBA rotors) and bolted back the drive member.
The drive shaft stub end now only has room for the circlip, and no room for the two shims. When I installed the whole assembly, there was no play, and adjusting the bearings was the usual. Still no play, so I can't figure out why the
shaft end is a tad short?? Help?
Old June 6th, 2006, 01:45 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Insert a bolt in the end of the CVs shaft (you'll see the threaded hole in the end of the CV shaft) and pull on it. The CV has end float (aka moves in and out). That should do it. If not, sometimes they get bound up when you install the hub and flange and you have the remove the drive flange again to get them free'd up. This will allow you to pull out on the shaft to get the shims and the clip on.
The end flot is real important so that you don't blow the CVs, so make sure it is set correctly.
Email:
Old June 6th, 2006, 02:50 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Thanks for the tip. I found the problem. When I inserted the whole assembly back on, the seal dislodged and got mangled. (I guess it was a little off when I seated it). I replaced the seal and repacked the bearings, and the assembly fit
as it should shims and all. BTW, that circlip can be a %#@!&* to put back on while holding the shaft out. But all in all, I survived my first bonehead move.. Now for the other front side, and I will be done with all four...
Old June 6th, 2006, 05:06 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Did you have a pair of circlip plyers, a good pair makes it easy.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old June 6th, 2006, 09:10 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Yeah, I bought circlip plyers but they sucked. Broke 2 tips. I ended up using them and regular needle nose in tandem.
Old June 7th, 2006, 09:02 AM
redrover
Guest
Posts: n/a
Also not mentioned and you probably did it -is to recess the seal 4mm inside hub lip. If not done you will get a false torque value on hub nut. JP
Old June 7th, 2006, 11:50 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Yes I recessed the seal 4mm, but not having the real tool to press the seal in, I used the old races and a mallet, to tap in the seal.That particular seal was tapped in, a little off (deeper on one side), so I believe when I mounted the assembly on the drive shaft, the seal and bearing popped off/dislodged at the back. When I pulled the assembly back off, sure enough the seal and bearing were slightly jammed on the shaft. The seal was damaged and the spring gaiter mangled. I re-checked the bearing races and they looked good and seated. Checked the bearings and no damage, so I repacked them, and installed VERY CAREFULLY the new seal at proper depth. I again VERY CAREFULLY slid the whole assembly back on, spinning the hub to ensure proper seating. Adjusted the bearing nut, placed lock washer and lock nut, drive member, and presto the problem was soved and the shims and circlip fit perfect. I just re-bled the front today, and went for a drive to set the pads by driving up to 50 mphr. and braking hard. I did this about 6 times before the pads settled in and the D90 braked evenly in a straight line. Serious braking power now on all four..SWEET!
axle, brake
Front Brakes and HUb Reseal bjf Defender Technical Discussions 24 December 4th, 2009 11:51 AM
Front Axle Needed! cbass Wanted 1 April 21st, 2005 09:17 AM
GBR 4.75 3rds and Extreme front axle setup for sale billnsandi For Sale - Parts 2 January 4th, 2004 11:10 PM
Front Rover9in axle Buckon37s Misc. Chit-Chat 6 December 8th, 2003 08:09 PM
