Front brake line - why hard line & flex line? - Defender Source
Old January 11th, 2012, 02:06 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I tried a few searches but wasn't sure how best word it so figured I would make a new post...while tearing apart the front end in my 90 last weekend for some much needed maintenance and new brakes I again reminded myself of a question I have had for a while. Why do the front brakes have a flex line that connects to a small hard line on top of the swivel ball and then to the caliper? Why not just have the flex line go straight into the caliper?
Old January 11th, 2012, 02:49 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Don't know the exact answer, but the hard line has to be bent in such a way that it clears the edge of the suspension spring & its base, so maybe they figured a stiff pipe would stay "in shape", whereas a flexible one might flop into a position where it could ge damaged?
Old January 11th, 2012, 06:47 PM
Jeff:
Out of curiosity do your brake lines have a bracket that holds them in place thats attached to the top of the swivel pin bolts? In other words the caliper can't be removed without undoing the swivel pin bolts? Was curious how it's setup on a NAS.
Old January 11th, 2012, 07:29 PM
So you'll have a way to hang it up when you do a brake job
Old January 13th, 2012, 08:11 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Jeff:
There is a retainer on top of the swivel ball and that is the connection point between the flex line and the short hard line but I can remove the calipers without pulling the any parts of the swivel pins. worst case is you remove the small hard line
Old January 13th, 2012, 09:03 AM
carlosz's Avatar
carlosz
Carlos
between the frame and axle you need a flex line in order to absorb the pivot pint of the steering, other wise a hardline cannot be used at a pinch point.
the reason it runs from the caliper to the swivel, is because the caliper does not need to be removed on a normal brake procedure, this was done so the the steel lines stay closer to the caliper so they in turn will not become entangled on debree while off roading and thus break away.
lr implied that the mounting of the rubber line high above the axle would better its chances of survival in off road conditions...(how often do we trek in debree deepen than 75%the height of the wheel?).
when you read the stuff they feed you in training class it makes sense, since the earlier trucks were designed with the intention that they would be off roaded on a normal daily basis.
the newer units althou capable are more bling than it's inventors ever had in mind.
brake, flex
13mm Front Brake Calip. Unit Bolt chrisvonc Wanted 2 July 31st, 2008 08:50 AM
FS D110 front brake calipers ECR For Sale - Parts 1 April 13th, 2008 08:10 PM
Hard brake lines! TwisteD90 Defender Technical Discussions 10 October 10th, 2005 12:12 PM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
White D-90 in front of Hard Times Cafe Bethesda SpicoliWouldGo Misc. Chit-Chat 2 August 16th, 2005 01:45 PM
