Front Axle Swap - Defender Source
Old April 29th, 2009, 09:40 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Front Axle Swap
Greetings to all. Been reading the site for awhile, and decided it was time to ask a few questions...
I am starting to gather the parts to do a LHD conversion on the 110 and I am hoping to kill two birds with one stone. I have a good local parts source so will probably get a complete front axle instead of swapping swivel housings. I am wondering if there is an RRC front axle that had vented non ABS brakes so I can get that done at the same time. Also, I have read some posts about differences in the width of the radius arms from year to year, anything to look out for there?
Any advice will be appreciated.
Old April 29th, 2009, 11:38 PM
Any RRC/Disco/D90 axle will work, but there are ones you would prefer to have and ones you would prefer not to have. RRC axles up to mid 1993 were 10 spline (no fun). All RRCs had calipers with two feed lines (ie, no good for D110)
Early RRCs and all disco Is had non-vented front brakes, however, this is not that big of a deal because new vented rotors are cheap and, since no Disco I or RRC had a single line vented width caliper you will be buying new calipers too.
All RRCs and DIs had the steering linkage with damper on the back of the axle where it is vunerable to damage.
So, what you want is a NAS D90 front axle, complete with all the steering linkage and radius arms. Failing that it is pick your poison. I would look for a mid-1993-1995 RRC axle as it would be nice to be able to use the second shock mount location in the future if you so desire and it will have the vented rotors and 24 splines. You will still need a new drag link and end, but it will your best bet. Third choice would be a disco one axle.
Confused yet?
Old April 30th, 2009, 04:25 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I didnt realize that if you swap a DI axel you needed new calipers? Does that go for the rear also?
Old April 30th, 2009, 06:11 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
And the bushings for the front radius arms do come in two different widths. First time I switched an axle, I though I was crazy when the radius arms wouldn't fit - had to press in new bushings
Old April 30th, 2009, 08:14 AM
D1 calipers will work with the narrower non-vented single line setup as found on many non US 90's and 110's.
I put a 97 disco rear axle under my '84 90. I disconnected the a-arm balljoint, lower shock mounts, the frame end of the trailing links, and the brake lines where they go into the T on top of the diff. That last one was because the disco abs axle had a split T that I did not want to use.
I am running the axles, cv's, stubs, hubs, calipers, and 1 disc (the other was only about 1/4" thick, swapped it out) from the 97 in my defender front axle casing.
I was not able to use the disco steering knuckles as they are rather different from the defender ones that I have.
so my plan to install the RH disco knuckle to enable a future LHD conversion was thwarted.
The disco front calipers were identical in every way that I could discern but the pads and the way the pads are retained is different.
Old April 30th, 2009, 08:46 AM
LRover's Avatar
LRover
J. Michael McCaig
The CVs in the early 110 front axles are gonna be stronger than the ones in the RRC/Disco and NAS D90 front ends (not sure of the cut-off date). I agree that swapping axles is going to be the easiest but I would do some research cause you may be able to build up a nice front end. Otherwise sell those CVs to me!
Old April 30th, 2009, 09:36 AM
yes they are much larger, but the inner axle is still only 10 spline on the diff end. not sure if they will fit in the later SPH housings. I am keeping all that stuff in the event I can find 24 spline inners for those cv's.
Old April 30th, 2009, 04:01 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Simple.
Buy a cheap Disco axle and it's radius arms for the Diff and the Swivels. Keep everything else from the 110 and call me and I'll set you up with some axles to fit those nice CV's.
Keith
Big, Red and ... aaa Red..
Old April 30th, 2009, 05:07 PM
Will the two line calipers from a ABS truck work with a non ABS system?
Old April 30th, 2009, 05:22 PM
All RRCs are two line (does not matter ABS or not). You can drill a hole between the two and plug one to make them work on a single line system, but I have not personally tried it.
I have some vented RRC calipers and some DI calipers and I am going to try to DIY my own D90 calipers out of them (RRC spacers and bolts and DI halves), but I have not done it yet so I am not sure it will work.
Ron
Old April 30th, 2009, 07:42 PM
The RRC stops better than my Defender, its non ABS and has the front vented discs solid rears, are the two line calipers better than the single Defender style? It seems the D-90 caliper upgrade with the vented discs is popular among the disco crowd?
Old April 30th, 2009, 07:55 PM
What year is your RRC? The ABS ones stop on a dime (or at least feel like they do) because of the pump in the system rather than vacuum booster.
Old April 30th, 2009, 08:21 PM
Its a 91 Hunter. I know the ABS trucks have remarkably good brakes considering the weight of the trucks.
Old April 30th, 2009, 08:26 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Its the system not the calipers. Much more pressure in the lines, on the Non ABS trucks, I dunno what it is except you might weigh them both.
Keith
Old April 30th, 2009, 11:14 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Wow, lots of great information guys, thanks. Sounds like there are few different options...
Ron, would love to hear if your hybrid caliper idea works - my local parts source owes me some parts for free in trade for an engine so I should be able to get any RRC or disco parts I need (just not a D-90 axle, unfortunately)
Old April 30th, 2009, 11:33 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
the pistons on the RRC and Disco calipers are considerably smaller than the pistons on the Lockeed Defender calipers whether the vented rotor type or not.
Keith
Old April 30th, 2009, 11:42 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Keith, would the spacers from a vented RRC caliper work in my 110 calipers? Seems like that would be the simplest solution for vented brakes. Also, are all Disco 1 axles equal, i.e. if i were to take your earlier advice and use the diff/swivels in my 110 axle?
axle, front axle
Front axle swap flippedrover Defender Technical Discussions 15 October 4th, 2007 08:54 AM
Front Axle Needed! cbass Wanted 1 April 21st, 2005 09:17 AM
GBR 4.75 3rds and Extreme front axle setup for sale billnsandi For Sale - Parts 2 January 4th, 2004 11:10 PM
Front Rover9in axle Buckon37s Misc. Chit-Chat 6 December 8th, 2003 08:09 PM
