Front axle questions - Defender Source
Old April 19th, 2014, 07:20 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
Replaced the front axle with one from a '96 RHD 110.
Problems: Front drag link end & bushings are too small for the bracket. Everything else fits just fine (holes underneath line up perfectly). Do I have to buy different drag links or different bushings?
The diff looks like it points up the way. Is this normal?
Thanks in advance.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old April 19th, 2014, 07:30 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
You need the later drag links, Same as a disco. Diff angle looks fine.
Ryan
84 110SW County LHD
07 L322 Vogue
Old April 19th, 2014, 08:48 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
Thanks! The local wrecking yard has a couple of Discovery 1's in stock so I will go get a pair of radius arms (Thanks Jeff).
Will Discovery 1 springs & shocks fit also? Towers? My springs are very rusty, and the shocks have some resistance but not much.
Paul.
Old April 19th, 2014, 09:18 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Originally Posted by Paul K View Post
All:
Thanks! The local wrecking yard has a couple of Discovery 1's in stock so I will go get a pair.
Paul.
Yes on the towers & such.
Old April 19th, 2014, 10:04 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks Ray!
Old April 19th, 2014, 10:12 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Hopefully Oregon's climate gives you some rust free donor parts in terms of shock towers; often just easier to buy those new when replacing shocks-likewise I've never had great luck getting the bottom nuts off front shocks if they've been on for any period of time. That may be a facet of the East Coast though. Good luck!
r-
Ray
Old April 19th, 2014, 10:19 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
r-
Ray
Ray:
It is very dry on this side of the state. I got the rear axle from the same D1 I'll be getting the other stuff from and there was very little rust. I'll likely go with galvanized towers eventually, but I'll probably do that when I replace the chassis.
I never have liked the way of undoing the nut on the bottom of the shock. PITA!
Thanks again!
Paul.
Old April 19th, 2014, 11:12 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Yea, that an east coast burden that you bare.
Central OR is damn near Nevada dry.
-Jeff
But it's damn friendly here and traffic is so light!
Old April 20th, 2014, 01:04 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
-Jeff
Central Oregon has a very similar climate to what we see here. I've seen more than a month go by with zero precip!
Paul, be sure to grab all of the nuts, bolts, and washers.
-Jeff
Copy that! I'm going to have the buys at the wrecking yard remove this stuff- doubt I could get to the radius arms, as they pull the wheels & sit the rigs down on the dirt!
Old April 20th, 2014, 10:28 AM
Paul,
What is said above is correct. I assumed you got the 96 110 axle complete with radius arms. The early arms are 87-89ish RRC and 90/110 to 93. Disco radius arms will work fine. Be careful removing the 4 nuts that hold the shock tower. The studs tend to break. Spray them down with PB blaster and use a wire brush to get the corrosion off the stud sticking above the nut.
Old April 25th, 2014, 04:40 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Which front Discovery springs should I use on my Ninety- a pair of rights, a pair of lefts or as they come? Turns out the springs are different lengths (& more coils) on the left vs. the right on a Discovery 1.
I didn't know this, but when I stood them up, one was taller. Went to the wrecking yard thinking they had given me a front & a rear, and they went & pulled both front springs off another Discovery 1. Same deal, drivers side is taller.
The old springs from my Ninety are the same height as the passengers side from the Discovery 1, but are thicker steel & appear to have less 'give'.
Which should I use on my V8 Ninety SW?
Paul.
Old April 25th, 2014, 04:45 PM
The two taller ones from the disco.
Old April 25th, 2014, 06:51 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks Ron!
Old April 25th, 2014, 07:02 PM
Long answer: Disco I spring are lighter spring rates than D90 so to get as close as possible two taller ones. Of course relative rates of sag etc make everything a crap shoot as to how not level things turn out.
Actually, I take that back. In theory: You probably want long one drivers side, short one passenger side since you have the side fuel tank. Honestly it does not matter all that much.
axle, front axle
83 110 front axle upgrade questions ArmyRover Defender Technical Discussions 9 October 30th, 2012 08:01 AM
1997 D-90 rear axle housing and 83' 110 front axle housing Tyler Wirken For Sale - Parts 0 January 3rd, 2012 06:31 PM
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
Axle or axle casing Departing90 Wanted 0 May 29th, 2007 08:45 PM
