Front axle question... - Defender Source
Old November 9th, 2009, 11:59 AM
Grover's Avatar
Grover
Question Front axle question...
Is it possible for the one-shot grease to leak into the front diff-case/pumpkin?
Cheers...
Old November 9th, 2009, 12:04 PM
Yes.
Bad inner seal would cause that.
Old November 9th, 2009, 12:25 PM
Related question if you don't mind the hijack - I use oil not one-shot grease in my swivel balls now and have a pretty good leak develop on one side out the hub cap. This would be an outer seal, not an inner one right (or could it be both?
Old November 9th, 2009, 12:49 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Is it leaking on your wheel? You may just need to re seal the flange with a paper gasket and/or some loctite on the bolts.
BTW I run oil in my bearings and swivel.
Old November 9th, 2009, 12:53 PM
Yes leaking on the wheel, but it's not the flange seal. It's leaking out the hole the axle shaft goes through in the flange.
I did damage the plastic dust cap when putting the wheel on once and that may be where it's coming from. But I assumed if it would come out a cut in the cap then it would come out the groove where the cap snaps into as well no?
Old November 9th, 2009, 01:26 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Charles, I had a nick in one of my dust caps where it leaked from, bit of super glue in the cut and it hasn't leaked since
3rd low and BOOT IT
Old November 9th, 2009, 01:49 PM
Ok I'll try this or get a new dust cap before anything else, thanks.
Old November 9th, 2009, 01:56 PM
enjoi1968's Avatar
enjoi1968
Blake Pendleton
98 D1
Charles, I am heading down to warrenton tomorrow afternoon (round 3pm) I'll be stuck in that parking lot known as 495 & 66. If you can suggest somewhere along my way to pull off I could drop you a new dustcap (and a reason to get out of the parking lot for a bit and calm down of course :D )
Old November 9th, 2009, 02:08 PM
I appreciate the offer but there is no rush - I have been running it like this for a while. I'm not that far from 66, but don't have the time to head out there tomorrow or I'd do it just for kicks. What takes you to Warrenton? Delivering some D1 parts?
Old November 9th, 2009, 03:13 PM
I switched to series metal dust caps. more durable. I'm eventually going to get the bolt on, screw cap flanges from RN. Those plastic ones are kinda flimsy, and if you go with a wet axles, your at risk of losing a bit of oil on the trail if the plastic cap comes off. (hasn't happened to me, but it was a concern)
Old November 9th, 2009, 03:38 PM
I did the screw cap ones on the 110 because I was tearing the caps on rocks. Really shouldn't be needed on the D90 though other than carelessness when putting on heavy tires. I like the idea of metal ones though. Aren't they longer than the D90 ones though?
charles
Old November 9th, 2009, 04:22 PM
Put some hylomar on the axle splines. Series trucks have a felt seal on the axle.
Old November 9th, 2009, 04:59 PM
enjoi1968's Avatar
enjoi1968
Blake Pendleton
98 D1
best friend from culinary school is currently living in Warrenton. Call of duty Modern Warfare 2 also comes out tomorrow..
With these metal screw-in caps that were mentioned, do those attach to the axel themselves? I just realized with my new steelies, my plastic dust cap will be exposed.
Old November 9th, 2009, 05:11 PM
Damn gamers
I think they are just a tap on snug fit onto the stub just like the plastic ones. Otherwise those HD replacement flanges are the way to go.
Old November 10th, 2009, 07:45 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Wouldn't it be faster to hop on 15 and bypass 495/66?
Jimmy Buffett
Old November 10th, 2009, 08:16 AM
Yeah that's how I'd go.
I guess I misread this one. These are replacement flanges with screw on caps. I am not sure, but they may interfere with the alloys so if you used them, you may not be ale to mount alloys without modification. They would work fine with steelies.
Old November 10th, 2009, 08:22 AM
I've had the plastic caps come off. Didn't leak much or cause any problems. Took a used one out of the junkpile at home and put it on. No biggie.
Old November 10th, 2009, 01:36 PM
enjoi1968's Avatar
enjoi1968
Blake Pendleton
98 D1
it would be if I wasn't leaving from Rockville...
Damn gamers
Come on, it's the ONLY game I do play...
I'm moving to steelies here soon (once I wear out the rubber on the alloys) so I'll be looking at the flanges when it comes to that point.
Old November 10th, 2009, 01:41 PM
Just giving you crap.
Here is what the replacement flanges look like btw.
http://www.defendersource.com/forum/...5&postcount=16
Old November 10th, 2009, 02:07 PM
enjoi1968's Avatar
enjoi1968
Blake Pendleton
98 D1
Just another day in paradise...
Thanks for the pic, looks like I'll be getting my hands on some of them here soon.
axle, front axle
Front Wheel Spacer / Axle Question johnpiero Defender Technical Discussions 17 January 11th, 2009 01:36 PM
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
GBR 4.75 3rds and Extreme front axle setup for sale billnsandi For Sale - Parts 2 January 4th, 2004 11:10 PM
Front Rover9in axle Buckon37s Misc. Chit-Chat 6 December 8th, 2003 08:09 PM
