Front axle options...? - Defender Source
Old February 13th, 2014, 07:40 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I took my Ninety in for an alignment, and the shop said they couldn't do one because the whole front end is so loose (also leaking at the seals). My front brakes are also shot. I did a search here, and it seems as though I have four options;
Option 1. Replace all the worn stuff on my current axle.
Pros: Get new stuff on the axle. Stay original (apparently stronger). No LHD to RHD swap.
Cons: Still need spacers. Parts harder to source.
Option 2. Swap out the whole assembly for a Discovery 1 unit.
Pros: Easier to get parts for it, front axle will match rear axle (I plan to swap it shortly), no more spacers.
Cons: Apparently weaker, will have to swap LHD to RHD, brakes may be smaller.
Option 3. Fit a Discovery 1 axle but transfer the stuff over from my axle.
Pros: Cheaper, get new parts.
Cons: Not much of an improvement over a Discovery 1 axle and parts?
Option 4. Source a RHD Defender axle from the UK.
Pros: Apparently stronger, will bolt right on, no more spacers.
Cons: More expensive, will take longer to get here, may still need new bushings, etc.
I am tempted to slap a Discovery 1 axle under there, but can't find a good source of info on exactly how to do the LHD to RHD swap. I don't plan any Dukes of Hazard type driving, so a slightly weaker axle shouldn't be an issue. I'd like to get away from having spacers.
Thoughts?
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old February 13th, 2014, 07:46 PM
Fix the one you have! Who is to say that the Disco 1 axle will be any better than what you have now.
Old February 13th, 2014, 07:48 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Biggest part would be no more spacers!
It's also ten years younger...
Old February 13th, 2014, 07:50 PM
I'll be brief in my response, but literally (for the most part) the only things that affect your alignment are the drag link & tie rod - that's it. And if the bars are straight, really what you're "adjusting" are the ball joint ends (which are replaceable).
Now that said, certainly swivel balls can *sort of* play into this, as can the bushings in your front radius arms & panhard rod. But really those technically won't affect your alignment.
My $0.02 - the shop sounds like the don't know what they are talking about if they say to replace the assembly. DO NOT replace the entire assembly. Not seeing it personally, but I'd probably replace the tie rod/drag link with a heavy duty set (with tie rod ends) from Lucky8, and assess the condition of the other said parts.
Old February 13th, 2014, 07:52 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Almost everything is the same right to left hand drive with the exception of the swivel housing. I just junked a rhd axle last august and put a lhd axle in my 110 when i did the frame swap. I would just get swivel seal kits, tie rod ends and bushings unless you want to switch to lhd then i would recommend just getting the whole disco axle cheap and throw all the same new parts at it then swap once its built..
Ryan
84 110SW County LHD
07 L322 Vogue
Old February 13th, 2014, 08:47 PM
Figure out what's loose and leaking and fix them. You can do an alignment with a tape measure so just do that if necessary (is it even necessary?) and be done with it. Sounds like you should try another shop for sure.
Originally Posted by pendy
I'm here for the D's
Old February 13th, 2014, 09:38 PM
ezzzzzzz
Mark Garrenton
What others are saying. Loose??? WTF does that mean? Take a shim out of each birfield assembly to tighten those up at bit. Pull the drive flanges and snug up the wheel bearing load. The tie rod ends might need replacing (seems they would have specified that). Make a slight adjustment to the steering box to take up slack. If you're not inclined to do that try another alignment shop...hell, try another alignment shop anyhow. Ignore the leaks...they all leak.
Old February 14th, 2014, 08:46 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I talked with Brian at Defenders NorthWest, and he echoed what's been said- go with Option 1.
How do I get the Freestyles to fit without spacers? I've heard you can pull the hub bolts and remove the washers, which sometimes works. Any other ideas?
Paul.
axle, front axle
Defender Snatch Sals Front axle atlcruiser The Vendors Loft 7 September 18th, 2013 10:07 AM
Front Wheel Spacer / Axle Question johnpiero Defender Technical Discussions 17 January 11th, 2009 01:36 PM
front axle shafts - are these stock on a 94 d90? cgalpin Defender Technical Discussions 7 July 22nd, 2008 10:25 PM
Front axle swap flippedrover Defender Technical Discussions 15 October 4th, 2007 08:54 AM
Front brakes axle shims won't fit... thewap Defender Technical Discussions 6 June 7th, 2006 11:50 AM
