Front axel vibes ... - Defender Source
Old August 31st, 2009, 12:53 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I now have a pretty bad vibe in my front axel, I checked the wheel bearings and they seemed good but when the front is off the ground and I turn the wheels I can hear a subtile clunking noise coming from inside the knuckles. So my question is when front CVs do go do the produce a bad vibe at around 50 mph ?
If it's the CV where to buy the best for an early Defender ?
Thanks !
Pat
Kirk Lazarus, Tropic Thunder
Old August 31st, 2009, 02:34 PM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
Good question. I get the same vibration around 50 mph, but my initial thought was that the prop shaft was unbalanced or got whacked by the big stick that also tore off the exhaust.
Pete
Pete
Old September 1st, 2009, 12:07 AM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
Peachyracer...check your panhard rod bushings. Have someone turn the wheel while you look for play. I had a vibration at 50mph and the bushings were bad.
Dunno about clunking with wheels in the air.
Old September 1st, 2009, 09:57 AM
Retrofit's Avatar
Retrofit
Pat
Anyone know of the associated problems with failing CV joints ? What to look for ? I know for a fact that my bearing are ok and all bushings have been checked. Pulling out the front drive shaft today for a test run, even though the u-joints are ok.
Pat
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Need 10 Spline Pass. Side Front Axel... h2eater Wanted 3 August 14th, 2004 09:57 PM
