front axel - Defender Source
Old May 29th, 2010, 02:13 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
front axel
How much, if any, movement should be present on the front axel when the brakes are applied? I mean forward and aft not side to side.
Old May 29th, 2010, 10:02 PM
Near zero. It should compress on the springs, but it should have no "fore and aft" movement.
Old May 29th, 2010, 10:43 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Dood,
He means axle wrap if I'm not mistaken. And these trucks have a buttload of it. Especially when the bushings start to wear. If the axle hasn't fallen out from under the truck, your cool.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 29th, 2010, 10:59 PM
No where near like a SOA leaf sprung truck.
Old May 29th, 2010, 11:42 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
I'm getting enough movement during braking that the track rod is hitting the sleeve intended to protect it. It has been evident since I've had this truck, 4 years, but I am chasing a new wobble and some other vague driveline issues. New pan hard rod bushings made the wobble much better but not perfect. As for the axel moving, it seems to make sense that if the axel is moving around something is going to wobble and effect the driveline. I just have to figure out where the worn bushings are. (I hope it's bushing because they're cheap)
Old May 30th, 2010, 01:07 AM
Do you have a three link? I has the SG tie rod protector on one of my discos and it was very tight fit.
Old May 30th, 2010, 10:56 AM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
No, but it is the same protector. After reading your responses and thinking about what happens, it may be the axel wrap. The axel casing kinda rolls forward or backward which causes the flex which causes the tie rod to hit the protector. I don't remember having that movement before on any other Rover, but then I have never had a tie rod protector either.
Old May 30th, 2010, 12:21 PM
My 1996 disco had that and the clearance was basically nil. IIRC it has some ability to be able to be moved forward or backward, if it is properly positioned I would think it could only be the radius arm bushings.
Old May 30th, 2010, 03:29 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I'll give you that, depending on the leaf springs your using.
But gentlemen, I have holes cut in my floor and I could watch what the pinion did during breaking and acceleration. I would guess that bitch would wobble over an inch.
------ Follow up post added May 30th, 2010 07:31 PM ------
If you replace the radius arm bushings it will help this. Of course, your articulation is directly inverse to the condition of the bushings.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 31st, 2010, 10:56 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
Thanks fellas. Radius arm bushings are next.
Old June 1st, 2010, 01:22 PM
I think of wrap as rotational, not fore and aft. Fore and aft I think of like how a leaf sprung truck compresses and moves back with the shackle on the rear of the front springs. In any event, I am not sure how wrap would cause the issue as, IIRC, the protector is bolted onto the axle housing which should remain static relative to the steering rod.
Old June 1st, 2010, 10:41 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
Yep, that's the movement I was talking about. Not sure the movement is that extreme, but certainly close. I am going to install some new bushing and see what happens. Thanks for the video.
Front axel vibes ... Retrofit Defender Technical Discussions 3 September 1st, 2009 09:57 AM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Need 10 Spline Pass. Side Front Axel... h2eater Wanted 3 August 14th, 2004 09:57 PM
