front +2" shock question - Defender Source
Old July 6th, 2014, 10:20 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
So looking to do +2 shock towers in the front of my 110 but unsure what shock to pair up with that. Brands aside what length shock either in terms of travel or compressed/extended lengths will work??
Thanks!
Defender 110
Old July 6th, 2014, 10:29 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
What are +2" towers exactly? Are they 2" taller, or shorter? Do you have a lift?
Lift springs, tire size, bumpstops will all play a role in determining shock length. I would recommend doing all other mods first, then determine shock length and if different towers are needed. Also take into account that radius arms will bind and that you may not be able to utilize a ton of downtravel.
Old July 6th, 2014, 10:34 PM
myoverlandrover
josh
109
Originally Posted by fishEH View Post
What are +2" towers exactly? Are they 2" taller, or shorter? Do you have a lift? Lift springs, tire size, bumpstops will all play a role in determining shock length. I would recommend doing all other mods first, then determine shock length and if different towers are needed. Also take into account that radius arms will bind and that you may not be able to utilize a ton of downtravel.
Sorry I have a 2" lift in the front and +2 towers are 2" taller than stock towers, all the rest is done In terms of radius arms etc. I'm trying to nail down the shock length ahead of time to eliminate down time with the truck.
Defender 110
Old July 7th, 2014, 02:23 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
If everything else is done but shocks the best thing to do would be to whip out the tape measure. Measure your shock length at rest. Then unbolt the upper shocks stems from the tower and flex the suspension. Take measurements at full compression and max extension. These measurements will give you hard numbers for shock shopping. See where you're at, what shocks will work, and if going to +2" towers is necessary.
Old July 7th, 2014, 02:24 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Didn't you already do the 2.5s?
Old July 7th, 2014, 06:54 PM
myoverlandrover
josh
109
Yes looking at fox 2.0 in the front
Defender 110
Old July 7th, 2014, 08:34 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
FWIW, I run 11" Fox 2.0's up front. 3" RTE springs, D2 shock towers, and custom lower adapters. Perfect fit.
Old July 8th, 2014, 01:34 PM
http://rovers.red90.ca/shockinfo.html
john (red90) has specs for stock shocks on his page. add 2 inches compressed length for the longer shock towers and whatever for longer bump stops.
" Wolf " Style Steel Rims 6.5" X 16" 2 3/4" javelinadave For Sale - Parts 3 January 27th, 2014 08:36 AM
OME Suspension/Spring "A" and "B" handing question. Daringer Defender Technical Discussions 9 January 18th, 2012 10:23 AM
"94" RRC SWB County $9,500 "ish" shawom For Sale - Vehicles 0 October 18th, 2005 08:39 PM
Difference between "WOLF" and "NATO" wheels? wicks Defender Technical Discussions 10 August 12th, 2005 04:23 PM
OME springs: "A" and "B"?? jaherring Defender Technical Discussions 3 October 30th, 2004 05:49 AM
