from LT77 to an R380 stubby in a 110 - Defender Source
Old September 3rd, 2015, 08:58 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Was wondering if the tunnel needs to be changed to fit the 380?
and any other changes required?
Old September 3rd, 2015, 09:16 AM
It is designed as a direct fit. No tunnel changes. You do need the newer diff lock linkage. No sure about release parts, but I think they are the same.
Ashcroft Transmissions
Note you cant use the LT77 diff lock linkage and will need the R380 type
Old September 3rd, 2015, 09:18 AM
michael67's Avatar
michael67
Michael White
110 Tdi
I did this conversion four years ago. No tunnel change. If I recall, the kit from Ashcroft contained everything except some of the transfer case linkage parts I needed; my LT77/LT230 had an older linkage setup and I had to buy new.
Old September 3rd, 2015, 09:27 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
many thanks
Do you remember where you bought the linkages from?
Old September 3rd, 2015, 10:00 AM
Make certain you get the special throw out bearing. I have a truck here with an ashcroft stubby r380 purchased from Urban and it was shipped with a regular r380 throw out bearing and the truck is here because the clutch slips.
Old September 3rd, 2015, 11:09 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Just went through this on a Disco R380. The right TO bearing is key (stay away from the HD shit) as well as clean fresh pilot bushing and TURN THAT FLYWHEEL.
Old September 3rd, 2015, 12:35 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
turn as in cut?
It was cut 18,000 miles ago, but i guess i should do it again if its out
Old September 3rd, 2015, 12:39 PM
If the clutch was done properly 18000 miles ago, I would not touch it. Same for any of the other stuff in there.
110, r380
R380 Vs LT77 - Real World Differences? turbodave Defender Technical Discussions 53 October 24th, 2015 09:54 AM
Stubby R380 re-built transmissions. globallandrovers The Vendors Loft 5 August 28th, 2015 06:20 AM
R380 Shorty / Stubby - What clutch parts to use? don Defender Technical Discussions 9 September 10th, 2014 09:21 AM
R380 stubby for a 200tdi tomaco1 Wanted 9 February 18th, 2013 06:08 PM
R380/LT77 transmission oil cooler and lines off a NAS 110 evilfij For Sale - Parts 0 March 29th, 2009 12:39 AM
