Fridges in the 90 ST - show me your setups - Defender Source
Old December 1st, 2013, 04:55 PM
looking at getting a Fridge for the 90
prime candidates are the ARB 50qt, an Ingle about the same size, possibly the Ingle 27..
i have the stock back seat and will probably work around the brackets. but not sure.
95' D90 - daily driver..
Old December 1st, 2013, 05:04 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Good choice. My Engel is the best money I ever spent on my truck.
The mount in my 110:
That's a piece of 3/4" birch that's carpeted and tied in to the Tithonus' reinforced tub with M8 stainless fasteners. I cut a very small and thin channel down the underside of the platform to accommodate the raised lip of the tub reinforcements. I use the Engel slide lock mount to carry the fridge. I ran Ancor wire to an outlet box constructed of a sealed Hammond enclosure with a marine-grade Blue Sea Systems 12V receptacle.
My D90 used a similar setup, except that the Engle slide mount was secured to a cargo box that was mounted in the tub of the truck.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old December 1st, 2013, 05:39 PM
personnaly I wouldn't put a fridge in an ST permanently due to risk of theft. Can you clarify your intended use? Were you looking for a permanent install, or just for trips?
Mark Kellgren
KM4BOR
Old December 1st, 2013, 06:07 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
We have new Ironman 50L fridges for $649 + shipping if you are interested.
RDavisinVA
Old December 1st, 2013, 07:03 PM
I run an Engel 15 for my ST and a 60 for my tow vehicle...
Old December 1st, 2013, 08:42 PM
Non permanent install.. Need something for the TAT.
I'll end up using it in the 90 and JK.
Old December 1st, 2013, 09:01 PM
Wait...TAT?? Are you doing the entire thing?
Old December 1st, 2013, 09:09 PM
Small chunks to start (time limited somewhat). Hoping to do 1-2 weeks this summer.
Old December 1st, 2013, 10:21 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Now that sounds cool!
Old December 1st, 2013, 11:51 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
I hard mounted the slide lock on the floor, the rear bench is still functional but you cannot have both operational using the larger engel 45. I am going with exmoor flip and locks and looks like it should not interfere.
Old December 2nd, 2013, 12:39 AM
chris snell
Chris Snell
87 Ex-MOD 110
Dan, seeing your 90 brings back happy memories. Gotta love the fun and good eats made possible by an Engel.
2013 LR4
Old December 2nd, 2013, 01:02 AM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
what route did y'all take across aquarius plateau and the henry mountains? Looks like a good trip.
...you'll feel better in a couple of days.
Old December 2nd, 2013, 01:20 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Engel
Chris,
After doing a trip with a fridge…hard to image doing it any other way. The quality of meals days into a trip is undeniable. Definitely good times. I am missing wide open spaces.
Old December 2nd, 2013, 08:25 AM
Rover doc, do you have any other shots of how it's mounted. That is pretty much what I was thinking of.
Old December 3rd, 2013, 03:36 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Robert I don't have any other pics readily available but once you pick your fridge size, slide lok etc it's just a matter of setting it down and making sure it clears the door, bench brackets etc. I took advantage of having my fuel tank dropped as I was refurbishing tank gard, fuel pump etc and had ready access for bolts for slide lok. I have 1mm of space between grab handle and mud uk rear door cover. The beauty of this set up is access to the fridge. Easy to open and peak in. Good luck. Dan
NAS 90 ST to a import 110? don Defender Technical Discussions 13 August 23rd, 2012 06:40 PM
Defender 90 ST door cards MJV For Sale - Parts 5 July 16th, 2010 10:41 PM
1984 Defender 90 ST 300tdi draaronr For Sale - Vehicles 1 July 2nd, 2010 09:35 AM
1995 Defender 90 ST 2468 with 43000 miles EXCELLENT CONDITION funrover For Sale - Vehicles 1 September 25th, 2008 08:52 PM
WTB: Full Roof Rack for a 90 ST mrfilson Wanted 1 August 7th, 2008 05:28 PM
