Fridge install in 110 2nd row between seats - Defender Source
Old October 6th, 2009, 03:00 PM
Question Fridge install in 110 2nd row between seats
I'm going to be doing this when I get back. Have a new ARB, and just bought two ROW style individual middle row seats from a UK breaker. I have the 60/40 now. My plan is to replace the hinge bolts for the 60/40 leg mounts with quick release pins, so that I can take out the 60 split bench when I want, and replace with a single fold up seat. Then I'll have two individual seats in the middle row with space for the fridge in between for trips. Nice thing is being able to go between full 60/40 bench people mover and long family trip hauler.
I've been searching all over google, and can't find any pics of 110's that either have the ROW 3 seats with middle removed and fridge in place, or two 40 split seats with fridge. Does anyone have any?
In searching, Tony Brooks' 110 had it, but it's moved on.
Old October 6th, 2009, 03:04 PM
I just ordered some packs of stainless clevis pins for the seat supports. Let me know if you want some.
Old October 6th, 2009, 03:05 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I actually never permanently installed it -- very easy proposition, though. The only issue for me would have been fabricating legs for the inner support on each seat -- they're supported by the center seat framework which really needs to be removed. Once you mock it up it'll make sense.
good luck!
Old October 6th, 2009, 03:19 PM
I actually ordered an extra right side proper vertical floor bracket for the leg (part circled in attached pic), so that when I pull the 60 bench out, the individual seat replacing it can have one leg mounted to the original bracket point, and the other leg on it's own installed bracket (as it won't reach the dual bracket for the 60 as you know).
Unless you are talking about some other support?
Old October 6th, 2009, 03:30 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Actually I mean the rear support.
Old October 6th, 2009, 03:48 PM
so you are talking about the flip down support? Here's the back of those seats. How does the middle support the outer seats then? I'm not visualizing it.
Old October 6th, 2009, 03:52 PM
Abrooks's Avatar
Abrooks
Tony Brooks
The "U" shaped piece under the center seat is integral to the center seat frame. However, at least on mine, the outer seats sit on the U. Removing the center seat frame necessitates coming up with another support for each side seat as the "U" would be gone.
Sorry I"m not explaining this better, though again it will make sense when you see it.
Old October 6th, 2009, 04:26 PM
well those are the seats I bought from the UK breaker, and I only bought two of them. I initially only plan to use one of them along with the 40 I have which has it's own U brace underneath. I think I know what you are talking about. Sounds like a perfect place to put a semi-permanent tool box underneath that seat as a base support.
Old October 6th, 2009, 04:34 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
My Fridge is mounted between the seats.
It was simple enough. I made a shelf that I attached to the body, I bult a support out at the far end so it could rest on the floor at footwell level behind the cubby box. i left enough room for some straps to hold it down with turn buckles and nylon strap. Under this I plan to put a box for my inverter.
For the outer seats I needed to make a riser for each to replace where they seat's rested on the middle seat..
Simple.. If I get a sec I'll try and post pics in the next day or so.
Keith
Big, Red and ... aaa Red..
Old October 6th, 2009, 04:41 PM
Thanks Keith, that would help. What I don't have is the outer seat outer brackets. I'll have to call the breaker and see if he'll throw them in the box too before they ship. Will those bracket outer mounting points be blocked by the locking assembly for the 60/40?
Old October 6th, 2009, 05:21 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
"Will those bracket outer mounting points be blocked by the locking assembly for the 60/40?"
I don't think so.
Keith
Old October 6th, 2009, 09:06 PM
surf110's Avatar
surf110
Ze
130 Project
Jim. Do you have a photo of those pins? If you have extra to sell. I'm interested.
Old October 6th, 2009, 09:36 PM
Check out part number 92390A234 at McMaster.com - they're flat-headed clevis pins, not the round-headed pins that are standard. You just use a cotter pin to hold them in. I took mine apart to powder coat all the components so I had to replace the pins with something. I figured the advantage in being able to detach the seat supports would outweigh the loss of originality - and of course, originality is not really an issue with my truck anyway.
If you like these pins I'll be happy to send them to you. They're only a few dollars, postage will be more, but I do have some cotter pins I can throw in as well.
Old October 6th, 2009, 10:38 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Something like this?
ID:	21999   Click image for larger version
Old October 7th, 2009, 12:25 AM
Matt,
EXACTLY like that! Details please! How did you do it? Please post for all.
Jim,
I'll take some of those clevis since you went through the trouble of finding a good match up, thanks for the offer. how many do you have left that came in that bag? I guess I would need 5 or 6 in my planned application.
Old October 7th, 2009, 12:45 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
That's pretty much how I mounted mine, although I mounted mine well forward of that for two reasons. First being able to reach a drink from the front seat is nice, and my drawer allowed me to flat surface the rear "bed" leaving a great place for the doggies to hang out..
i'll try to get pics tommorow after shipping and the parent teacher conf...
Mark? Shouldn't you be in bed?
Keith
Old October 7th, 2009, 01:18 AM
It was 7AM when I wrote that! I'm GMT+8 hrs right now.
BTW, the fridge part is easy, I'm interested in how Matt setup two individual seats. Is that two 40's from a 60/40 split with a chopped 60 or a modified extra 40? Or something else?
Old October 7th, 2009, 01:52 AM
mattarm's Avatar
mattarm
Matt
1993 D110
Not my setup. I am pretty sure those are pics from Jesse Ware's 110 that was for sale a little while back.
Old October 7th, 2009, 06:44 AM
surf110's Avatar
surf110
Ze
130 Project
Jim. Thanks for the offer on the pins. I'll just buy straight from McMaster. They're here in CA.
What about something like this?
Old November 21st, 2017, 01:04 PM
SummitRover
1988 Land Rover 110 CSW
I am looking for individual second row seats like those in the picture.
110, seats
2nd row seats for 110 Overlander Wanted 5 November 21st, 2017 04:29 PM
Defender 110 Second Row Seats Rugbier Wanted 16 November 21st, 2017 01:36 PM
110 rear /2nd row seats Uncle Douglas Wanted 9 November 21st, 2017 01:34 PM
Rande Rover seats in 110 artm Defender Technical Discussions 4 February 10th, 2005 11:11 PM
