Frame Rust. How Bad? - Defender Source
Old February 19th, 2008, 03:19 PM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
How bad do these look?
TIA!
ID:	12227   Click image for larger version
Old February 19th, 2008, 03:26 PM
turbodave
Dave C
1983 110
Honestly?
I bet there are a lot of folks that wish theirs was that good... It needs some attention to stop it going worse, but it doesn't honestly look that bad to me.
Old February 19th, 2008, 03:29 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
That would be about a 3 or 4 year old truck in New England.
ditto, check for holes behind the trans crossmember
Old February 19th, 2008, 03:33 PM
Emerson00
Matt J.
None at the moment
Speaking as the least experienced member of the board, I'd say it isn't bad at all. I'd spray with waxoyl and forget it.
Old February 19th, 2008, 03:42 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
i'd wirebrush it, paint it, then hit it with waxoyl
First, take a hammer to it, if the hammer goes through it, then its bad... otherwise, it still has strength.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old February 19th, 2008, 03:46 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
I am AMAZED at how many "how to fix"/"what to do about" things on this list include the phrase "take a hammer to it" or "hit it with a hammer"
Old February 19th, 2008, 03:49 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Actually it is sound advice in this instance.
x2 on the waxoyl application. Flush the inside of the frame and apply there as well.
EwS
Old February 19th, 2008, 03:55 PM
Quimbola's Avatar
Quimbola
Josh
Thanks guys!
Old February 19th, 2008, 03:59 PM
rmuller
Ryan
If you hit it with a hammer, and the hammer goes through, the piece of metal is useless, no saving it... wouldn't you rather find out with a hammer in the driveway, then on the highway when the truck falls apart on you?
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old February 19th, 2008, 04:08 PM
Emerson00
Matt J.
None at the moment
First hand experience: tapping it with a hammer will do no harm to solid sections, but will be really revealing on dangerously rusted areas.
DAMHIKT... or do.
Old February 19th, 2008, 05:03 PM
bharris's Avatar
bharris
Brad Harris
I never meant to suggest that hitting it (or whatever else goes wrong on a defender) with a hammer wasn't the right thing to do...
I just think it's funny
and you know... I probably need to get a bigger hammer
Old February 19th, 2008, 05:24 PM
Emerson00
Matt J.
None at the moment
starter motor problem: hit it with a hammer, see if it's siezed
frame rust: hit it with a hammer... see if it's rusted through
What else?
Old February 19th, 2008, 05:29 PM
Removing ball joints (hit arm with TWO hammers at the same time).
Old February 19th, 2008, 05:41 PM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
For a squirel or other small animal in the air vents... hammer can be useful.
Old February 19th, 2008, 05:45 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Gotta Love it!
Gotta love that "Speed Wrench"! (Politically correct Version)
Old February 19th, 2008, 07:36 PM
check your fluids, it's too dry back there!
Old February 19th, 2008, 07:49 PM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
ever hear the song "hammer time" by m.c. hammer. enough said.
WHO OWN THE CHIEFS? OWNZZZ OWNZZZ
my e-mail:
Old February 20th, 2008, 12:31 AM
rmuller
Ryan
Can't get a bolt out? chisel + HAMMER! According to my Polish friend, it is referred to as a Russian Wrench
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
FS NAS D90 take out frame, no rust ECR For Sale - Parts 8 June 13th, 2009 02:03 PM
Severe frame rust! Bowtracer Defender Technical Discussions 15 March 31st, 2005 02:18 PM
Project D90--high miles, blown engine, bad trans, rust, body damage evilfij Wanted 5 November 12th, 2004 09:26 AM
