Frame differences? - CSW vs Tithonus 110 - Defender Source
Old January 21st, 2014, 02:27 PM
Streaky's Avatar
Streaky
Alden
1994/D90 NAS
Does anyone know the difference between the frame from a:
Tithonus 110 (1987 w/2.5NA) versus a 110 County SW (1983 w/2.5TD)?
Looking at swapping the tithonus frame (from Chris) into the CSW.
Any major difference? Motor mounts should be the same, yea?
Old January 21st, 2014, 02:57 PM
Frame should be the same. Only differences will be brackets bolted on to mount the body. Someone will correct me if I am wrong.
Old January 21st, 2014, 03:09 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I just did this sort of....I used a newer exmod frame to replace the 84 csw frame under mine...the only difference was the bolt in cross member under the transmission..other then that i just moved the body and all the brackets over to the new frame and bolted everything down.
Ryan
84 110SW County LHD
07 L322 Vogue
Old January 22nd, 2014, 08:34 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The engine mounts might also be different
Old January 22nd, 2014, 08:47 PM
Willing to bet that the chassis is heavier duty than civilian LR.
Old January 22nd, 2014, 08:59 PM
Are you doing it because yours is rusted out? It'd be a good time to have it galvanised.
110, tithonus
Rockware frame sliders for a 110 AmityD90 For Sale - Parts 9 June 1st, 2013 11:34 AM
1967 Nada 109, on 110 frame btate For Sale - Vehicles 9 November 23rd, 2009 09:26 AM
Decent 110 Frame Wolf Fabrication Wanted 8 September 17th, 2009 05:30 PM
New 'rebuilt' 110 CSW bound for the USA - Not one of ours. globallandrovers Misc. Chit-Chat 22 August 26th, 2009 10:12 AM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
