Frame bracket for brake lines? - Defender Source
Old June 13th, 2013, 10:10 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Anyone have a picture of the bracket where the hard brake line meets the soft line in the front of a 90. On my old frame (1985) the holes in the bracket were the perfect size for the soft line to past through. On the new frame (1997) the hole in the bracket is almost twice the size it needs to be? Wondering how to secure the lines to the bracket. It doesn't seem secure the way I'm doing it with 2 fender washers and nut.
Old June 13th, 2013, 10:33 PM
They have a big nut on the soft line on NAS D90s.
Old June 14th, 2013, 12:02 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
These are extended stainless lines I was talking about Tom. This is my 97 NAS frame, hope this helps.
ID:	74399   Click image for larger version
Old June 14th, 2013, 05:51 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
even with the nuts on there, it seems kind of half-assed.
Old June 14th, 2013, 07:44 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Not sure I understand? The stainless line has two nuts that secure the line to the support, the other is a double female bc they did not sell double fluted female ends? Any way good luck
Old June 14th, 2013, 09:38 AM
Tom, you could always weld up the hole and redrill it, or maybe weld or braze a thick washer to the bracket for a more permanent solution. Is there enough room for fender washers both sides plus the jam nut and star washer? Are you using the thin jam nuts?
Brian your setup looks fine though I try to avoid those adapters if I can. They do work well in a pinch. You can always save the proper english nuts (that sounds funny) from the old lines. BTW the hard line in your first pic looks like it might be cross threaded.
Old June 14th, 2013, 09:48 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I thought the same thing when I saw it last night. I was out there til well past midnight messing with it. I pulled the wheel, I think it is just the angle of the picture. I replaced all my lines, when I swapped the frame and no one had female ends only male ones. It was my first time using those fittings and they where a pain in the ass, but I couldn't find anyone that had brake lines in stock back in Feb. I might replace in the future but for now they are fine.
Old June 14th, 2013, 01:06 PM
Does paragon performance still sell the rover brake line kits for the SS flexible lines? I need to dig mine out.
bracket, brake
Flex fuel lines - from the tank to the frame SIIA109 Defender Technical Discussions 12 July 31st, 2010 01:07 AM
How straight is a typical Defender frame? madcowdungbeetle Defender Technical Discussions 9 August 22nd, 2009 05:43 PM
Rear A-Arm Frame Brackets..etc TDI Guy Wanted 14 February 16th, 2006 09:15 AM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
