Fox Shocks vs. Bilsteins - Defender Source
Join the Defender Source Community Today
Old May 15th, 2012, 01:43 AM
CDeWan
Clay DeWan
5.3L beastie
I don't have the model number of the fox shocks but they don't come with an additional resevoir. How hard are they to rebuild and do folks prefer them over HD bilsteins or...
Thanks in advance...I know it is kind of a vague question.
Clay
Old May 15th, 2012, 09:25 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
I like the Fox shocks I have on my disco - rebuilding doesnt seem difficult although I havent done it myself I saved this video for the day when I would have to -
Old May 15th, 2012, 11:43 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I just bought a pair of Fox Emulsion 2.0 Non-Res for the fronts. I haven't installed them yet (as I am piling some parts together and will do a full front end fix and clean-up) and cannot comment on how they work yet. But they do look bitchin'!
Old May 16th, 2012, 11:15 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Have them on all fours and love them ...
Pat
Kirk Lazarus, Tropic Thunder
Old May 17th, 2012, 06:49 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
The Fox are IMO (and I have used abused and broken both the Fox 2.0 em and the comparable Bilstien 7100) much easier to rebuild and factory support is much better. I have not broken a Fox shock yet but I have broken several Bilstiens. The finish on the Fox shock is much more durable.
I'm not sure that there is an appreciable difference in actual dampening performance. The Bilstien has very poor bottoming protection, so you need to make sure that is sorted properly as even a light bottoming / topping can cause damage. I have experienced fade in the non reservoir versions under heavy use.....they get really really hot.
Matt Browne
Old May 17th, 2012, 09:34 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Matt - fade on the non-res Bilsteins or Fox or both?
Old May 18th, 2012, 10:34 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
i hear Kings are the way to go. i think lucky8 sells em.
Old May 19th, 2012, 02:23 AM
madcowdungbeetle
Carter
Fox, King, Sway-A-Way, you really can't go wrong. I currently have Bilstein 7100's with remote reservoirs on my D90, and I do not care for them, or their construction. I had Sway-a-ways on my Disco. I liked them, and they are easy to rebuild and revalve. I think my D90 will be getting Fox Coil-overs next... for the sole reason of color.
Old May 19th, 2012, 06:57 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
In the non reservoir versions both would suffer if valved heavily enough to almost work on a heavily sprung Range Rover.
As Madcow has mentioned, the higher end shocks by SwayAway, King, Fox and even Bilstien will offer a huge increase in performance, but a huge increase in price.
In a more convention shock the Koni "raid" offers surprising performance. I have installed some on a customer rig (D90) and am quite surprised by the performance. They are non bling and simple and priced somewhere between the standard and high end at I think about $250 ea, plus they are a bolt in. Some of the higher end shocks will require additional work and expense to mount efficiently.
I thought the 6k in suspension I have on my race bike was steep......buddy of mine just did a Ford Ranger pre runner and spent $2500 per corner on King coilovers and bypass shocks.......just for the hardware, and he still needs another $1000 in frigging bumpstops!
Matt Browne
Old May 19th, 2012, 01:07 PM
madcowdungbeetle
Carter
It depends on the type of wheeling that's been done. I am 100% remote reservoir on any rig that I own. If you are just doing slow rock crawling, basic trail riding and DD'ing then you should get by on emulsion shocks no problem. If you are running harder trails on a heavily loaded truck or at speed on rough terrain, then the remote-reservoir setup is definitely the way to to.
Old August 31st, 2015, 01:05 PM
RickM
Rick Mabus
95 D-90 ST
Going to revive this. I saw some comments on here about remote reservoir. What is the benefit of having a remote reservoir. Please forgive me as I am new in trying to dial up my suspension.
Old August 31st, 2015, 01:36 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I'ma Fox dude... remote resi front/rear on my disco. Love the setup. Necessary? No... you likely won't ever see a need in daily driving for a remote res setup. Helps with heat dissipation
Old August 31st, 2015, 01:39 PM
In a monotube shock, the biggest advantage of a remote reservoir is that it gives extra travel in the same form factor, as it moves the pressurized air and dividing piston out of the shock body and into the reservoir.
What the pros care about is whether or not the rebound and compression are adjustable, and how these parameters can vary along the travel of the shock. If you want to have the best of the best, then get a shock with 8 bypass tubes and a 1 inch thick shaft. You'll pay a lot of money and you'll feel better about yourself as a person as you drive to the grocery store.
Or just buy cheap shocks.
Old August 31st, 2015, 01:53 PM
So a question about Fox shocks, which ones would pair with OME Medium duty rear and Heavy duty front springs?
I hate the terrafirm setup i have now and will be swaping it out, i need 1-2" lift.
95' D90 - daily driver..
Old August 31st, 2015, 02:18 PM
Originally Posted by rlynch356 View Post
So a question about Fox shocks, which ones would pair with OME Medium duty rear and Heavy duty front springs? I hate the terrafirm setup i have now and will be swaping it out, i need 1-2" lift.
Nothing wrong with the OME shocks with your set up.
Old August 31st, 2015, 02:24 PM
that was my go to option (just buy a HD Kit and resuse my medium duty rears and if needed i can swap them for HD)
just wanted to get an option on fox shocks.
Old August 31st, 2015, 02:36 PM
If planning to purchase shocks in the normal price range, just get the Koni SPX shocks. They are much better than the run of the mill shocks like OME.
Old August 31st, 2015, 03:16 PM
If for some reason you feel compelled to spend more than $100 / shock, I would really recommend going with the Fox 2.0 Rebuildable.
I bought the OME nitrochargers for the front of my truck and I regret the decision badly. Not because they are bad shocks, but because they are overpriced.
For $20 more, I could have bought full alloy Fox 2.0 Rebuildables that don't rust like the Bilsteins.
I put $45 Racho 5012's on the rear of my truck and I don't regret it at all.
Old August 31st, 2015, 04:29 PM
SO what about those FOX shocks rovers north has been pushing? They are direct fit, I dont have interest in changing out shock mounts etc.
Ive never heard anything bad about Koni shocks, maybe its because so few are using them. ive got some leaking OME shocks on both of my Rovers. The FOX get a lot of respect and the bolt in and go that Rovers North is selling are very appealing.
Some cursory reading on the interweb suggests that the OME are re-branded Monroe, I see lots of yellow Monroe shocks.
Old August 31st, 2015, 04:38 PM
Originally Posted by rover4x4 View Post
SO what about those FOX shocks rovers north has been pushing? They are direct fit, I dont have interest in changing out shock mounts etc. Ive never heard anything bad about Koni shocks, maybe its because so few are using them. ive got some leaking OME shocks on both of my Rovers. The FOX get a lot of respect and the bolt in and go that Rovers North is selling are very appealing.
Are the RN shocks rebuildable 2.0's?
Fox, like every manufacturer, makes several lines of non-rebuildable shocks that are essentially no different from a cheap Monroe or KYB.
IMHO, the bare minimum buy-in on Fox shocks are the rebuildable 2.0's. Anything less and you might as well buy a no name gas charged shock. Seriously.
And we will all respect you no matter what decision you make. Unless you plan on running KOH with your truck...in which case we might make better suggestions on a shock.
bilstein
Fox Shocks part # sajidd Defender Technical Discussions 0 November 24th, 2006 03:07 PM
Fox shocks leaking... AggieD90 Defender Technical Discussions 9 March 19th, 2006 01:32 PM
Fox Shocks? Joe P Defender Technical Discussions 11 November 29th, 2004 04:25 PM
Service on Fox shocks chrisvonc Defender Technical Discussions 1 June 14th, 2004 09:52 AM
Fox Shocks Valving Buckon37s Defender Technical Discussions 1 May 25th, 2004 06:47 PM
