Fox Shock Question - Defender Source
Old May 26th, 2011, 09:06 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Fox Shock Question
I have been reading through old threads for a couple hours now, and have read a lot of info on fox and bilstien shocks. I know somewhere on this board my question has been answered, but I have not found it.
I am running RTE 2" springs with EE retainers. I am currently on Rancho 9000 and am wanting to upgrade. I do drive the defender on the street pretty regular, but it is mainly an off road toy, and family camping rig. My question is what bilstien and fox shocks can I run with this set up? Also, what valving would you recommend? Currently my fronts are 9.5 travel and rears are 12" travel. I have no sway bars, RTE rear links, and new RTE radius arms on the way. Trying to maximize performance. Thanks
That is why it is called a short cut. If it was easy it would just be "the way."
Old May 27th, 2011, 08:24 AM
Oliver Whiting
Oliver Whiting
84 110, 94 NAS90,Bunch of EX-mods
shocks
Call Bilstien and tell them what you are up to. They will give you the number to the off road tech guys in California. I had the names and numbers but cannot find them. These guys will talk your ear off but know all the numbers for valving and length. It's a pretty firm shock valving for stock springs but you have a heavy version spring and the valving may need to be reduced a bit.
Old May 27th, 2011, 09:28 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
I was running 10" FOX remote reservoir on my 94 at all four corners. They were valved at 85/95 but I was running OME springs and don't know how their spring rates compare to your RTE's. I wonder if your actually cycling the full 12" in the rear. I had EE's spring retainers too and a properly positioned 10" was long enough. I also had a custom 3 link in the front a was able to cycle a full 10" there too. Without drop out cones in the rear I would question needing a 12" rear shock. I would take off all your shocks and measure your extended and compressed lengths before ordering anything.
Hope this helps
Will these work? Shock spring question. tomaco1 Defender Technical Discussions 0 May 5th, 2009 09:34 PM
Fox shock help snurp Defender Technical Discussions 13 January 27th, 2009 09:13 AM
Procomp +2" shock question headdamage Defender Technical Discussions 1 September 5th, 2007 02:03 AM
Really dumb shock question Neo Defender Technical Discussions 1 August 9th, 2004 01:20 PM
Fox Shock dealers Berty Defender Technical Discussions 3 June 28th, 2004 04:16 AM
