Fox/Bilstein shock questions - Defender Source
Old September 18th, 2009, 08:46 PM
d90dan's Avatar
d90dan
Dan Berry
1995 D90
Anyone know the extended/compressed length of this shock?
Fox
I'm working on my front suspension and want to use Fox, but I'm having a hard time finding the right lengths. Well unless I cut and weld, which I'm not opposed to just need to get it done quick.
I did find the bilstein 7100 10" SB is just about right using Disco II uppers and an eyelet adapter on the bottom. I'm running RR rear springs up front and my max acceptable compressed length of 17", so 14.3 compressed + ~1.5" for the adapter will work. The springs fall out ~28" extended and this shock should be about 25.8 max extended with adapter. Any thoughts? Advice on 7100 shock valving for the 180lb spring rate on a ST?
Thanks!
Dan
Old September 19th, 2009, 06:19 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
If you go to the Fox website, they have a pdf file in the offroad shock section with all of the compressed/extended lengths of the 2.0 non-coilover shocks (also all their others). If you find what you want order it from polyperformance. AA manufacturing makes brackets for converting the fox shox to allow it to be mounted into a location requiring a stem shock.
Old September 19th, 2009, 12:22 PM
Treuwer's Avatar
Treuwer
Trae Reuwer
94 D90
The AA website was difficult for me to navigate
Is this the right part?
What do you then do with the res? Will it all fit inside the coil... I need to go measure.
Old September 19th, 2009, 01:21 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
On the A&A site - look up aa-501. That with carriage bolt and welder - cheaper.
bilstein
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
Old Man Emu Shock Life - and 4 questions COSteve Defender Technical Discussions 13 April 1st, 2005 04:39 PM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
