Four clutch master cylinders in 90,000 km - Defender Source
Old September 18th, 2014, 08:55 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
It's leaking, again.
I'm thinking about cutting an access door on my left wing for speed changing :-)
More seriously, is there any brand that will last more than 20,000 km ?
Cheers
- Charles Eames
Old September 18th, 2014, 09:44 PM
Is your exhaust cooking the fluid and ruining the clutch master seals?
Old September 18th, 2014, 09:45 PM
sleeve in brass and be done forever. search threads for "brass" for vendors
Mark Kellgren
KM4BOR
Old September 18th, 2014, 10:11 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Not as far as I know, but I will check where routings come close.
------ Follow up post added September 18th, 2014 10:11 PM ------
Sounds good, I'll search.
------ Follow up post added September 18th, 2014 10:17 PM ------
Found it, Apple hidraulics
- Charles Eames
Brake Master Cylinders Scottyoh The Vendors Loft 0 March 26th, 2014 10:40 PM
What other brake servos/master cylinders work? o2batsea Defender Technical Discussions 1 July 10th, 2012 10:51 PM
On master cylinders: AMC:1, Land Rover: 0 michael67 Misc. Chit-Chat 4 November 4th, 2010 11:02 PM
Anti-freeze in cylinders boxerhips Defender Technical Discussions 4 January 30th, 2006 01:38 AM
110 Wheel Cylinders - How often do they fail? COSteve Defender Technical Discussions 7 March 11th, 2005 04:27 PM
