Found vacuum hose loose on what looks like the fuel rail PVC valve - Defender Source
Old May 26th, 2013, 11:28 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
In doing some cleaning on the back of the engine, I found what looks like a vacuum hose dangling from a valve that is on the passenger side at the fuel rail. The valve is situated with the air intake pointing towards the driver's side. Does anyone know where this attaches or is it supposed to be only connected to the valve? Thanks.
Old May 26th, 2013, 12:37 PM
flananuts
Matthew
Does that have a vacuum line attached? I can post a pic if needed. Unfortunately I cannot find anything in the workshop manuals
Old May 26th, 2013, 03:24 PM
Post a picture for instant assistance.
Old May 26th, 2013, 04:30 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I think I know what you are referring to- there is a vacuum line the runs for the fuel pressure valve on the fuel rail ot the very back of the plenum---if you are standing in front of the truck, where it plugs in is in the back of the plenum, upper right corner. Sort of hard to see--a mirror might help.
Old May 27th, 2013, 07:35 AM
flananuts
Matthew
Davis, I think you nailed it. Thanks for the help.
Old May 27th, 2013, 09:07 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
And sorry for my description of location on where it plugs into the plenum---I should have said upper left when looking from the front---my brain pulled a dyslexic moment...
Old May 29th, 2013, 12:11 PM
flananuts
Matthew
Hey Davis, does it plug directly into the back of the plenum or under? I was feeling around and I could not find it? I will definitely try a mirror to see if I can find where it disconnected. I'm actually feeling the negative effects of not having that plugged back in where it belongs.
Old May 29th, 2013, 12:49 PM
You can probably find the diagram telling you where everything goes if you google "vacuum diagram 3.9 land rover"
Old May 29th, 2013, 01:03 PM
flananuts
Matthew
thanks guys, will take a look at vaccum diagram as well as stepper motor. Appreciate it.
Old May 29th, 2013, 01:06 PM
The diagram should also be in here if you search vacuum or something like that. Save this owners manual link to your favorites on your computer and your smart phone.
http://www.internet-tools.co.uk/land...l%20(1993).pdf
Old May 29th, 2013, 07:27 PM
flananuts
Matthew
you guys are great!
fuel, vacuum
I need help with the brake booster vacuum hose routing Chip Defender Technical Discussions 0 August 30th, 2012 12:52 AM
Fuel Tank Breather valve cbass Defender Technical Discussions 2 March 18th, 2008 03:09 PM
Vacuum pump TDI300 gali Defender Technical Discussions 1 June 5th, 2005 12:11 AM
fuel filler hose mattdh Defender Technical Discussions 2 October 31st, 2003 08:17 PM
