Found in my oil pan? - Defender Source
Old May 29th, 2014, 07:54 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I just dropped the pan on my newly acquired 300tdi and found a couple of little metal shards which is not a good thing but will happen over time. I am a little concerned with the remnants of what appears to be a 1/4" diameter white plastic washer that I found in the dregs of the used oil. I couldn't think of anything inside of Diesel engine that would be made of plastic. Does anyone know where this plastic might have come from?
Old May 29th, 2014, 08:25 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Could it be a part of the dipstick assembly?
Old May 29th, 2014, 09:14 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I will try pulling that out but I am not sure if I will know if something is missing from the assembly. Are you thinking it would be like a seating washer around where the dip stick goes into the block?
I am not sure it's big enough for a dip stick to have passed thru the hole. I am guessing the entire washer was 1/4" in diameter with the hole being fairly small. It seems like it could be a buffer between two pieces that a screw goes thru.
Old May 29th, 2014, 09:34 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by RockShow View Post
I will try pulling that out but I am not sure if I will know if something is missing from the assembly. Are you thinking it would be like a seating washer around where the dip stick goes into the block? I am not sure it's big enough for a dip stick to have passed thru the hole. I am guessing the entire washer was 1/4" in diameter with the hole being fairly small. It seems like it could be a buffer between two pieces that a screw goes thru.
sometimes the dip stick itself has an o-ring. Not usually nylon but I'm not 100% sure.
Very strange, might have just been a hitch hiker if it's as small as you say
Old May 29th, 2014, 10:09 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Accidentally went in with an oil change, made it down an oil return passage and settled in the pan?
Email is
Same place, new dogs.
Old May 29th, 2014, 12:23 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
That was kind of my natural skepticism as well but I can't figure out where you would have plastic inside the engine. My only thought was maybe something in the oil pump as I don't know anything about the guts of tdi pump.
Old May 29th, 2014, 12:43 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I had an oil sprayer tube floatting around in my sump for a long time. Only reason I found it was because I had to have the sump pan removed to take out a dent.
These things aren't like a Porsche or Ferrari where the think will explode if you lose a hangnail inside the engine while filling the oil. There could be anything inside there, and as long as it's not a piston skirt I wouldn't be that concerned.
Old May 29th, 2014, 02:23 PM
This. Remove, discard and carry on. At next oil change, send a sample out to have it analyzed. that will tell you if you have bearings failing, etc.
Mark Kellgren
KM4BOR
Old May 29th, 2014, 03:54 PM
Proving once again, that a Land Rover doesn't need all the parts it comes with.
Old May 29th, 2014, 05:56 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Lol; spare bits, surplus to your needs
Found in a 200tdi oil pan? tomaco1 Defender Technical Discussions 20 February 14th, 2011 11:49 AM
Dropping my oil pan... sflash868 Defender Technical Discussions 6 May 19th, 2006 12:01 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
