Found in a 200tdi oil pan? - Defender Source
Old February 11th, 2011, 09:27 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'm a bit concerned I found this in the oil pan.
I had just run it and it ran fine.
Any ideas what this is?
ID:	35706   Click image for larger version
Old February 11th, 2011, 09:55 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
Is it metallic or non-metallic? If metal, is it ferrous?
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old February 11th, 2011, 09:59 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
It is Metal
Old February 11th, 2011, 10:35 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Its a lash cap. Better adjust your valves. Probably need to replace all the lash caps now and then adjust.
legend in my own mind
Old February 12th, 2011, 07:00 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Can these get all the way to the bottom without doing damage?
Do they have another name? I can find it in the Parts book or manual.
Old February 12th, 2011, 07:04 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Funny to see that today. Yesterday I opened up a 200 that was running but not well and it was missing 5 of those "lash" caps. Someone had adjusted it to run better I'd guess. Now the valves are all peened and new caps will not fit on. Valves are going to be a pain in the arse to service..........another "tune - up" gone bad....
Matt Browne
Old February 12th, 2011, 07:48 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Hey Matt,
Where did you get the lash caps? I don't see them anywhere online
Old February 12th, 2011, 09:05 AM
Pretty sure this is what you want.
http://www.lrseries.com/shop/product...err4175&page=1
------ Follow up post added February 12th, 2011 07:17 AM ------
Or LJC100270 seems to be the same.
Old February 13th, 2011, 07:38 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Sorry for the slow reply.......I only get to see a computer for a few minutes a day......
RN has the caps use the part # John just gave you. If you have issues finding them give me a shout as I have some in stock.
Matt Browne
Old February 13th, 2011, 07:54 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Old February 13th, 2011, 07:57 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
here you go http://www.roversnorth.com/store/p-1...ap-300tdi.aspx
Originally Posted by tomaco1 View Post
Hey Matt,
Old February 13th, 2011, 07:59 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I assume 200 and 300 are the same?
Old February 13th, 2011, 12:09 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I never use the OEM part anymore. Just get some hardened lash caps for an air cooled VW engine. Much better part then stock. I do not believe the stock parts are hardened enough.
Good time to upgrade your valvetrain. The VW parts are like 10.00 most places.
If you do not have a VW speed shop in your area just search vw hardened lash cap on ebay
Old February 13th, 2011, 01:57 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
http://cgi.ebay.com/ebaymotors/Lash-...#ht_1210wt_839
Gracias!
Old February 13th, 2011, 03:27 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Jim do you find most of the oem parts to be inferior? Are there particular aftermarket parts makers that you find better and those you stay away from?
Old February 13th, 2011, 04:41 PM
pendy's Avatar
pendy
jim pendleton
89'd90
No I do not find most of the OEM parts inferior.
But lash caps have long been a weak point in these diesel engines.
As another said. "I do this all day every day" So most of my experience and knowledge is hands on.
Your question "Jim do you find most of the oem parts to be inferior? Are there particular aftermarket parts makers that you find better and those you stay away from? "
Could be answered specifically in a very long diatribe by someone who uses a RAVE cd and memorazation skills to promote themselves as an expert of sorts. Thats not me. If you have a particular part in question and it amuses me to give you my take on it, I may. Beyond that, I like to get paid, because I have enough practice already.
Old February 13th, 2011, 04:49 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks for solving my mystery!
Now to order them and get them in!
I'm hoping they can be fitted while doing the Valve Adjustment.
I still can figure out how it got from the top down to the oil pan?
Old February 13th, 2011, 04:57 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Through the oil drain of the cylinder head. More then likely you will have others up in the cylinder head broken into pieces as well. Yes they can be changed during valve adjustment. Rule of nines is best way to adjust valves. have described this before here. You can search it if not familar.
Old February 13th, 2011, 05:11 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Just watched the Video,
Thanks Again
Old February 14th, 2011, 09:46 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
All the lash caps seem to be in place, and they appear to be smaller.
I was wondering if maybe it could parts of this?
200tdi, tdi
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
