Found in 300tdi Oil Pan...what is it? - Defender Source
Old October 9th, 2014, 02:07 PM
US110CSW
Mark
67 109" Hybrid
Hey folks,
Here is a game I love to play...what was the source of this destructive bit of metal. In all honesty, I'm looking for your expertise to tell me if I need to tear this engine down or not. I found this bit of metal in the sump of my 300tdi oil pan. it is steel and has the letter R cast into it. There appears to be another letter following it...possible O as in "FRONT" but I have no idea.
Which of you very experienced Rover Junkies can tell me what it's source was?
Thanks for looking...and hopefully solving the mystery
ID:	104626   Click image for larger version
Old October 9th, 2014, 02:10 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Originally Posted by US110CSW View Post
Hey folks,
Pull the rocker cover off and inspect the rockers…
Old October 9th, 2014, 02:12 PM
the rover shop
shayne young
It's the electrode off the sparking plug..
Old October 9th, 2014, 02:13 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Appears to be a US dime? Cant tell the year from the back
Old October 9th, 2014, 02:14 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
+10 points to shayne for not saying 'its a dime'
------ Follow up post added October 9th, 2014 12:14 PM ------
-10 points to zack
Old October 9th, 2014, 02:18 PM
__
|R|
Old October 9th, 2014, 02:19 PM
Hey folks,
Floor sweepings placed in the engine by striking British workers as sabotage.
Old October 9th, 2014, 03:04 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Suspect this is just debris that made it's way into the engine and settled in the oil pan where it sat unnoticed until now.
It is too large to be sucked into the oil system, so it couldn't cause any harm.
The only concern is what happened to the other 25 letters???
RDavisinVA
Old October 9th, 2014, 03:38 PM
the rover shop
shayne young
Just give it a kick in the r's..
Old October 9th, 2014, 03:54 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Turn the dime over, maybe it is of a collectible year and mint mark.
Old October 9th, 2014, 05:07 PM
the rover shop
shayne young
Puhhleeease... I wouldn't do something like that.....That would just be lame...
Old October 9th, 2014, 05:33 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You're just upset you didn't think of it
Old October 9th, 2014, 09:28 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I think the real question here is...how the hell did you find that little piece?
I mean, were you sifting through your oil change pan?
Or do you have a magnetic plug?
Rent my
Old October 10th, 2014, 12:13 PM
US110CSW
Mark
67 109" Hybrid
Exactly what I needed, THANK YOU!
------ Follow up post added October 10th, 2014 11:18 AM ------
I had a hole in the oil pan and took it off to weld it. While I had it off, I was cleaning it up[ and found that chunk and a small rock at the bottom of the pan...who knows. I'll pull the rocker cover when I get it off the hoist and drop a picture of the damage in this thread.
Thanks everybody!
300tdi, tdi
Found in my oil pan? RockShow Defender Technical Discussions 9 May 29th, 2014 05:56 PM
Found in a 200tdi oil pan? tomaco1 Defender Technical Discussions 20 February 14th, 2011 11:49 AM
300tdi Oil Pan bitz Wanted 0 July 7th, 2010 02:17 PM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
