Ford Injectors? - Defender Source
Old August 20th, 2015, 11:12 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Ford Injectors?
What real world experiences do people have swapping out the injectors for Ford injectors?
  • Any improvement in performance?
  • Any improvement in MPG?
  • Which model injector did you use?
  • Where did you source them?
thanks
Old August 20th, 2015, 11:14 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Which specific Ford injector into which specific engine?
RDavisinVA
Old August 20th, 2015, 11:23 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Going in to a 4.6, but I'd like to know which model(s) people have successfully used.
Old August 20th, 2015, 12:26 PM
ezzzzzzz
Mark Garrenton
A early 90's Mustang stock 5.0 injector (yellow top I believe) would work fine. The flow rate is 19lb/hr which will support up to about 295 hp. I've not done this yet but am leaning this way for a 4.0 build and a 2.8 SC'd L6 going into my 240Z.
Old August 20th, 2015, 12:52 PM
psykokid
Jake
1997 Disco
Also yellow Bosch gen 3 injectors used in the later Volvos are a perfect fit. Bosch P/N 0280155746. Easy to find at the junkyard.
Fits:
1995 850 Non-Turbo with Automatic Transmission and Motronic Fuel System
1996-1997 850 Non-Turbo with Emissions Code 1, 3 ,4 or 5 (The emission code is the 8th digit in the VIN)
1998 S70 Non-Turbo
1998 V70 Non-Turbo
1994-1997 960
1997-1998 S90
1997-1998 V90
Old August 20th, 2015, 01:33 PM
ezzzzzzz
Mark Garrenton
Awww, gen 3 injectors should work better with the multi-nozzle design vs the single pintle. I'll have to investigate that too.
Old August 20th, 2015, 01:41 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Remember we are dealing with a bank fired EFI system here. Probably no more efficient than a carb.
Old August 20th, 2015, 02:37 PM
ezzzzzzz
Mark Garrenton
Probably not a idle but off-idle might be a bit different. Anything to improve performance/economy is a plus. Cost are comparable so go with the later design.
Old August 20th, 2015, 03:11 PM
psykokid
Jake
1997 Disco
Better fuel atomisation with the gen 3 injectors versus the earlier single pintle ones. On my "upgrade" list as soon as I get a few more injectors on my next junkyard run. Will probably make a bigger difference with my truck since it's a SFI GEMS injection versus the earlier batch fired 14CUX injection.
Old August 20th, 2015, 05:51 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I put some into my v8 and really couldn't tell a different. I imagine the spray pattern is better and everything else is better but performance felt the same.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old August 20th, 2015, 11:47 PM
Zero difference on all counts except they can be had for a few bux.
Old August 21st, 2015, 08:37 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks Bill. Do you say that because the difference in the injectors is minimal or because the standard rover v8 can't leverage any improvement from the ford injectors?
Old August 21st, 2015, 09:28 AM
down_shift's Avatar
down_shift
Russell
Good overview: Siquential vs Batch Injection | Fuel Injection Options | ECU
Old August 21st, 2015, 11:57 AM
I say that because the ECU's fuel management lut is burned into the PROM. It will adjust injector bandwidth to meet that. You can't improve performance by basically changing nothing.
Old August 21st, 2015, 12:01 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I'll need to check with the guy that burned my chip to see what it'll support.
Old August 21st, 2015, 12:14 PM
From my experience in the tuner world: It's unlikely to do anything unless you've done something to increase the amount of air going into engine. Or increasing the compression ratio to get more out of the fuel.
Ever thought about a turbo or nitrous?
leaking diesel injectors seaswood Defender Technical Discussions 5 July 18th, 2008 07:49 PM
North American Source for Bosch 300 Tdi Injectors? AggieD90 Defender Technical Discussions 5 June 29th, 2008 07:18 AM
Can I swap THOR injectors into my '94? Hans Defender Technical Discussions 2 May 8th, 2008 01:20 PM
FS Rover V8 injectors ECR For Sale - Parts 0 March 11th, 2008 12:28 PM
fuel injectors not working matt Defender Technical Discussions 1 May 24th, 2007 06:28 PM
