Forcing Torque Converter Lockup - Defender Source
Old September 9th, 2007, 02:52 AM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
My '97 D-90's auto-box is running hot, especially while towing my trailer: consistently above 220 degrees on long uphills. I've replaced the stock transmission oil cooler with two parallel radiators, each with thermostat-controlled electric cooling fans, without a lot of benefit.
So, I'm wondering if reducing slippage-generated heat, by forcing the torque converter to lock up, might be a solution? As I understand it, the ZF 4HP22 transmission's torque converter only locks in fourth gear. But when I'm slowly pulling my heavy trailer up a long incline, I'm usually in second.
Are there any transmission gurus out there who could say whether there's a safe/practical way to get the torque converter to lock up in lower gears? Is it an electrical or mechanical actuation? From what I've read, the ZF 4HP22EH (electro-hydraulic) transmission used on the Discovery Series II does allows for torque converter lock-up in all four gears, but is there any way to do this with the 4HP22?
Thanks in advance,
Trevor
Old September 9th, 2007, 03:48 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I have seen aftermarket torque converters for such applications for other makes. the housings look the same as the rover version, I am sure there is a common manufacturer for these that you could cross reference.
http://www.tciauto.com/Products/Maxi...converters.asp
Old September 9th, 2007, 04:34 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Its in the valve body not the torque convertor. Difficult to do. Off road you can use the brake and the gas to do it.
I may have seen information about this, but cannot recall just now.
JP
legend in my own mind
Old September 10th, 2007, 10:29 AM
Michael
Michael
Discovery 1998
220 is not ideal, but not that bad for towing on long hills. If I remember correctly, the stock temperature switch on my Disco grounded at about 250 - or was it 220? - will check and verify.
Use amsoil?
Lowering the stall speed in the converter should lower temps prior to lock-up. I am not sure how much the stall speed can be lowered without stalling the engine.
Old September 10th, 2007, 10:33 AM
Trevor, how are you measuring the tranny temps? A sensor on the cooler?
Old September 10th, 2007, 11:59 AM
Trevor Tarr
Trevor Tarr
A sensor on the sump. (Each cooler also has a sensor, but these only control the coolers' electric fans.)
Michael, thanks for your suggestions.
I keep coming back to the "transmission life halved for every 20 degrees above 175 degrees" rubric. I'm always at least 220 towing uphill, and frequently higher. At 250, I'll pull over to cool down.
Use amsoil?
I'm using Mobile One ATF.
Is there a way to lower the stall speed?
Old September 10th, 2007, 12:35 PM
Michael
Michael
Discovery 1998
yes, stall speed can be lowered by professionals. Pendy recommended I do this for my diesel re-power. Call up your local transmission shop and ask where they send torque converters to be repaired/rebuilt. There is a place near me called Converter Technologies that does this. They quoted about 250-300 to do it. The million dollar question is how low can you go without reinstalling it and finding out it stalls the engine when you put it in "D". Maybe get a torque curve for your engine?
Torque Converter for TDI300 Disco Auto Eddie 1 Defender Technical Discussions 3 September 27th, 2007 01:52 AM
Torque Converter re-Install trouble Michael Defender Technical Discussions 3 November 6th, 2005 09:18 PM
Only one catalytic converter??? opinions?? cbass Defender Technical Discussions 7 August 10th, 2005 10:30 PM
Proper waterpump torque? cgalpin Defender Technical Discussions 11 April 17th, 2005 09:45 PM
